Thread: programing language help!
November 19th, 2003, 10:37 PM #1Junior Member
- Nov 2003
- 4
I am a crim. justice major and I am interested in learning about the language involved with computer progam hacking. I need a starting point...what should I look into first??
November 19th, 2003, 10:47 PM #2Not Really a Member
- Oct 2001
- 27,856
"the language involved"...
One problem with that statement
Which language?
ANY language can be used.
C/C++, VBScript, java etc.
It also depends on how you define "hacking"
If you mean hacking into a network, that is too open ended of a question.
If you mean hacking code in a application that is another very open question.
It also depends on how technical YOU are?
If you're 99% lawyer, and 1% technical.. you need different information vs a professional developer.
I'm guessing you're not a developer though! call me crazy
So we need more information.
What specific part of "hacking" are you researching?
Many times in "hacking" people use pre-written utilities (ala script kiddies)Helicopters don't fly; they vibrate so much and make so much noise that the earth rejects them.
November 19th, 2003, 10:51 PM #3
Well all programs boil down to assembly, and there directly to binary.... but starting from the bottom is madness
November 19th, 2003, 10:56 PM #4Junior Member
- Nov 2003
- 4
Thanks for the quick reply...I think networking...im looking for information about learning languages that can be used to commit cybercrimes. Some language skills that can enhance my resume...
November 19th, 2003, 11:18 PM #5Not Really a Member
- Oct 2001
- 27,856
If you want to find exploits that people have wrote (of which sources will not be found on this forum) most times they're fairly low level so written in C/C++ or maybe if you're "lucky" written in Assembly
Beware C/C++ are not easy languages to learn so they'll take some work on your part.
Its not just plug and play.Helicopters don't fly; they vibrate so much and make so much noise that the earth rejects them.
November 19th, 2003, 11:54 PM #6Junior Member
- Nov 2003
- 4
Is c/c++ language the basics of all or the majority of program writting?
November 20th, 2003, 01:55 AM #7
C/C++ is not the basic of all programs, some uses C/C++, some uses Java, some uses Visual Basic....but to learn about hacking, C/C++ is the one to learn, just beaware its also the hardest language to master, so good luck
Shuttle sb75G2
P4 3.2 with 800fsb @3.4GHz
Corsair XMS Pro (2 X 512)
ATI 9800 Pro : Raptor SATA 10k 36G
Polyvision N-3302 30" LCD !!!
November 20th, 2003, 10:39 AM #8
I would suggest a basic understanding of the UNIX operating system as well (and actually before any programming language). You gotta' know how to navigate and work with files.
I think Chuckie should go to jail for slinging such obvious BS, lol . . .
Voter Suppression is Alive and...
