Join TechIMO for Free!
Thread Tools
Currently Active Users: 2127
Discussions: 186,677, Posts: 2,227,826, Members: 230,321
Old January 5th, 2002, 12:26 PM   Digg it!   #1 (permalink)
Lightbulb
clonecd AHHHHHHHHHHHHHH!!!
hi guys,
I'm having a problem on CLONECD. The problem is, it won't "Read to image file", "write from imagefile" and "copy cd" The games i want to backup are The sims hot date, AVP2 and Harry Potter, but either of them will do anything, The 2 buffer bars at the bottom are always on 0% and the progress bar is always on 0%. However, i can see the drives working (trying to do something!)I have used Clony to get the burning options to it, which are manualy.
I have done Toca2 easily on it via clony without any probs. So why don't these games work??
-My cd writer is a LITE-ONE 24X10X40 Burnproof.
-I'm running Windows XP home edition
-I have the latest Clonecd and Clony
-My cd burner and cd driver are both sharing the secondary ide port, while the hard drive is on its own on the primary ide port.
I don't understand whats wrong!!
is there something i have to enable or something, change the buffer size?... etc...
ur help will be greatly apprechiated!
Thanx
FifaHeat
Fifaheat is offline   Reply With Quote
FREE instant scan
Old January 5th, 2002, 03:47 PM     #2 (permalink)
SecretNinja999's Avatar
I've found that there are some CD-ROMs which CloneCD cannot even copy. The games you have listed are all newer games, perhaps the CD Protection isn't allowing you to burn them.
Check the LOG file when you are trying to copy a CD and see what errors are showing up.
To access the LOG file go to TOOLS >> Log. If the CDs are protected with a protection which CloneCD cannot bypass then you will see "error reading from CD" or something like that.
SecretNinja999 is offline   Reply With Quote
Old January 5th, 2002, 04:09 PM     #3 (permalink)
i don't think its that m8 because ive seen loads of ppl who have copied these games easily using clonecd.
Also, ive tried using the cdrw(liteon24x10x40) to copy to an image then to a cd, but it still wont work.
Old January 5th, 2002, 04:19 PM     #4 (permalink)
swamp-fox's Avatar
From what I've learned on here you should put the cdrom as slave to hdd and burner to master on secondary. Don't know if that will fix your problems though. I just got mine hooked up and copied 3 cds 1 music and 2 data and no problems yet
swampy.
swamp-fox is offline   Reply With Quote
Old January 5th, 2002, 05:18 PM     #5 (permalink)
aznlurkerz's Avatar
Send a message via AIM to aznlurkerz
i've always had 100% sucess with clone CD "my fav. backup progie" I think the harry Potter one is not "back-up :able:" it has the new cd protection. Try just to copy a image first or give Nero 5.5 a try.
aznlurkerz is offline   Reply With Quote
Old January 5th, 2002, 05:23 PM     #6 (permalink)
kcrispin3's Avatar
Send a message via ICQ to kcrispin3 Send a message via AIM to kcrispin3
to help narrow down problems, i suggest you try a test copy of an older game or music cd and see if they copy. If so, then its not your hardware config that is ~~using the problem. This will also eliminate any software configuration problems from teh possibilities list.
kcrispin3 is offline   Reply With Quote
Old January 5th, 2002, 06:34 PM     #7 (permalink)
i tested toca2 on clonecd and it worked fine!
Could it just be that:
Harry potter
Hot date
Avp2
have all new versions of a cd protection, so it cant copy.
wouldn't it lower ur harddrive performance if u put ur cdrom on the same ide?? i thought it would....
Old January 5th, 2002, 06:42 PM     #8 (permalink)
thekemp's Avatar
the games above mentioned i have working ''backups'' of but they are not copied disk to disk the are done another way. these games are SAFEDISK games and therefore , contain 'bad sectors' or similar technology i am not 100% sure therefore a normal cd-writer will not copy the disk as it sees parts of the disk as unreadable.
thekemp is offline   Reply With Quote
Old January 5th, 2002, 06:45 PM     #9 (permalink)
kcrispin3's Avatar
hmm, what version of clony are you using, and how are your IDE drives configured?
also, make sure your cd burner can burn in DAO-96 mode
Old January 5th, 2002, 06:50 PM     #10 (permalink)
my drives are configured like this:
Primary ide port: Master: harddrive
Secondary ide port: Master : cdrom
slave: cdrw
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (660)
Best Boot Drive Imaging Software (9)
Bought an AGP "HIS Radeon HD 3.. (18)
Video card compatability. (7)
File associations (5)
Outlook add-in won't remove. (10)
Is this a good laptop for gamming? (6)
Misery Loves Company... (1873)
Presario Help (6)
Lenovo 3000 N200 Laptop for $39.. (2)
BOX OF BOOKS FOR SALE!!!!!!!!!!.. (1)
[Help] Computer Freeze (4)
Putting together my wish list (21)
Acer SA80 Upgrade (2)
Best Boot Drive Imaging Softwar.. (9)
Computer won't start (10)
Fallout 3 problem (2)
Move folders from desktop to My.. (2)
graphics card driver issue (1)
What graphics card range for q9.. (1)
