Car stereo "kick = dim"
Currently Active Users: 1961
Discussions: 200,936, Posts: 2,379,217, Members: 246,300
Old December 4th, 2003, 04:31 PM     #21 (permalink)
Xtreeme's Avatar
No-dont need a cap for a head unit. Be the first I heard of that did. And Ive installed tons of sound systems both car and home audio. I shoulda run into one that needed it by now-LOL. At 25 to 30 some watts avg x4 why would you need it.
R.I.P. TKOP
Xtreeme is offline   Reply With Quote
Old December 4th, 2003, 09:22 PM     #22 (permalink)
joker_927's Avatar
I turned on the headlights and dash lights at night time, and turned the radio up darn loud. The lights on the deck were sure dimming, and I could barely take the noise, but the headlights and dashlights stayed steady.
Seems okay.
BTW: When I have my headlights on, and I switch on the AC, they dim a little bit, and stay dim. Just BARELY dimmer, to where you can only tell the difference at the moment you hit the AC button. Is this normal or a sign of a dieng arternator?
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Tagan 480w
joker_927 is offline   Reply With Quote
Old December 4th, 2003, 09:32 PM     #23 (permalink)
Banned
thronka's Avatar
The omly reason you wire it to the fuse box is to 1) protect the unit and 2) pick up AM radio stations. You can get a filter from autozone for this problem. Not sure on the model number.
thronka is offline   Reply With Quote
Is It Just Me? (2893)
Wireless Televisions. (8)
Obama the Muslim (14)
Modern Warfare 2 freeze (13)
windows 7 problem (3)
Point and Shoot Camera Suggestions. (1)
CPU fan stops spinning randomly (3)
wireless user (1)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
