Car stereo "kick = dim"
Currently Active Users: 1631
Discussions: 200,909, Posts: 2,378,931, Members: 246,276
Old November 30th, 2003, 10:31 PM   Digg it!   #1 (permalink)
joker_927's Avatar
Car stereo kick = dim
Is it bad when you turn your stereo up and the lights on the deck "dim" whenever your speakers "kick"?
LOL
Where is the power being drained? Can it be "upped"?
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Tagan 480w
joker_927 is offline   Reply With Quote
Old November 30th, 2003, 10:39 PM     #2 (permalink)
golfcart's Avatar
Is it only the lights on the stereo or is it all the lights in the vehicle? If it's just the radio, make sure it has a good solid ground connection. That's the most likely culprit
golfcart is offline   Reply With Quote
Old November 30th, 2003, 10:41 PM     #3 (permalink)
joker_927's Avatar
Yea, it's only the lights on the deck. Ewww, checking for ground connection, that seems like a tedious process. I just thought it was because the speakers were using a lot of power like when your washer kicks on and the lights in your hous dim for a split second.
Old November 30th, 2003, 10:57 PM     #4 (permalink)
golfcart's Avatar
That is very possible, but not normal with a good quality head unit. It could happen if you have too low of an impedance on it too, like connecting more speakers in parallel.
Old November 30th, 2003, 11:03 PM     #5 (permalink)
joker_927's Avatar
It's a new car... By memory I can remember the deck is about 5 years old, is a Pioneer, and says 34W x 4 on it. I honestly have no clue how the speakers are setup.
Old November 30th, 2003, 11:33 PM     #6 (permalink)
Now in the nicer ghetto
butch81385's Avatar
Send a message via AIM to butch81385
the lights did that when my altenator went out on me (but my speedometor also malfunctioned and my headlights also went on and off.... then my altenator, belt, and battery all went on me....)
I don't like signatures.
butch81385 is offline   Reply With Quote
Old November 30th, 2003, 11:41 PM     #7 (permalink)
Kuasimodem's Avatar
Send a message via MSN to Kuasimodem Send a message via Yahoo to Kuasimodem
You need one of these
I'm running two of them on my system (1000W total power)
Kuasimodem is offline   Reply With Quote
Old November 30th, 2003, 11:44 PM     #8 (permalink)
joker_927's Avatar
wtf is that? Are you serious? Considering I don't have any subwoofers just four 6 inchers I think. I honestly don't know, but I don't have HUGE stuff in the car.
I would like to know the problem before I find a solution.
Old November 30th, 2003, 11:51 PM     #9 (permalink)
Kuasimodem's Avatar
OK, if that's a bit much for ya, there is one other option...
Don't wire the deck into the fuse panel (or the factory stereo power wiring). Run a wire directly from the battery, with a circuit breaker or fuse located at the battery for protection. The wire should be at least 8 guage to handle the current needs of the deck.
This should provide enough power for just a deck.
BTW - The 1 farad capacitor that I linked to above stores energy and then releases it to the deck/amplifier when it needs it, like during the bass beats.
Old December 1st, 2003, 01:35 AM     #10 (permalink)
joker_927's Avatar
aNY PICTURES OF HOW IN THE HECK TO WIRE IT LIKE THAT? Oh crap sorry for caps
Will doing that help perserve my alternator?
Is It Just Me? (2813)
HIS HD5770 graphic card question (14)
Foreign voltage (6)
Print spooler problem (7)
EVGA 9800 gtx help with finding a g.. (7)
Mysterious Boot manager (9)
Asus P4G8X Mobo (3)
windows vista security holes (2)
World's largest Monopoly Game using G.. (329)
EVGA 9800 gtx help with finding a goo.. (7)
Need hard disk drivers (4)
Boot Problem? (0)
Logitech G9 laser gaming mouse $59.95.. (2)
$5 off any item with the purchase of .. (1)
Foreign voltage (6)
hybernate option (2)
