Results 1 to 20 of 20
    FLAC Trooper ArcticFox's Avatar
    Jan 2003
    A theater near you
    5,424
    Is 300w enough for this sys?
    I currently use a basic, Enermax 300w for my:
    AthlonXP 2500+ OC'd to 3200+ (1.83Ghz to 2.2Ghz, stock voltage, 400Mhz FSB)
    Asus A7N8X Deluxe
    2x 256mb DDR400
    Ti 4200 @ 300/500
    Maxtor 80GB 7200rpm
    LiteOn 40x12x48
    SB Audigy
    I'm planning on adding an ATI 9800np sometime, but need to know if I should get that Antec True480 I've been eyeing first. Anyone got a similar config/advice/anything??
    Thanks!
    Ultimate sumfin i guess Omardeth's Avatar
    Mar 2003
    sacramento ,ca
    3,267
    i wouldn't think so but it also depends on the rails . try it before you buy a new power supply . it might werk out .
    Jan 2003
    A theater near you
    5,424
    Well the rails are all within tolerable, but not spot-on as this is just a basic, no-frills PS.
    Apr 2003
    Texas
    1,292
    I have the same basic setup with the 2500+ oced and a 9800np and it is running just fine with my 300watt sparkle.
    Jan 2003
    A theater near you
    5,424
    If your running the same as I will be with a Sparkle of all things, I feel much relieved about things. I do plan on upgrading to a True480 anyways, it's just that I scored some extra cash and want to get a 9800 first rather than second.
    Member Shawn711's Avatar
    Mar 2003
    Auburn Washington
    473
    I have the A7N8X Deluxe with a Soundblaster live platinum soundcard, Radeon 9600 np video card, WD 100 Gig hd, Sony 52x cd burner, and generic 10x DVD drive and had a Powmax 400 watt power supply which ran great for about 6 mos. but ended up having to replace it when I started getting errors, random reboots etc. That was the second "cheap" 400 watt power supply that I've had in this system since I put it together and learned that skimping on the power supply is really not the way to go on any board, but especially with the A7N8X.......I have a A7V that has been running with a "cheap" 400 watter for about 3 yrs. with no problem, but it seems that this board demands a better power source.........I went with an Antec True 430 and it resolved all my problems and even increased my processor speed slightly..... with the generics it my XP 2200+ was running about 1.797 Ghz and now with the Antec, it is running about 1.804 Ghz stock.........I believe it is actually running cooler as well, because of the more stable and steady power source and probably running much more efficiently.......I personally would recommend buying the better power supply first since they are not as likely to drop in price with newer models, but video cards seem to drop quite frequently with newer technologies .......plus, your power supply could start acting as mine did without any warning.......even more likely with the smaller power supply and overclocking........hope that helps
    Shawn
    Shawn
    Jan 2003
    A theater near you
    5,424
    Thanks for the info Shawn. The reason is that I may be able to get a 9800 this Christmas if I can eek out another $100 or so from my rich grandparents. What I may end up doing is getting the card, trying it for a bit to make sure it works, and put it off until I get a bigger power supply.
    San Diego, CA
    6,399
    I've got a pretty similar config with one difference... I'm running an Enermax 350 watt psu. The system looks something like this
    EPoX 8RDA+
    2x512 PC2700 Corsair XMS @ 2.77 volts
    Barton 2500+@3200+ @ 1.7 vcore
    BBA 9800 Pro
    DVDRW
    DVD-ROM
    7200RPM 8MB Cache Western Digital HDD
    6 Case fans (2 lighted)
    2 Cold Cathode tubes
    Audigy 2 Platinum
    Dazzle Video capture card
    TV Tuner card
    SCSI card (for an old scanner)
    Modem
    Thats about everything and I don't have a problem with it, but you're also running 50 watts less so basically I agree with what was said earlier... Try it and see.
    Jan 2003
    A theater near you
    5,424
    That's a tonne of stuff.....I feel even better now.
    Member thegladiatorgy's Avatar
    Oct 2002
    Georgetown, Guyana
    383
    That PSU probably be adequate. I have a 400W Allied with 5 HDs, 3 CD drives plus the usual specs.
    Jan 2003
    A theater near you
    5,424
    What's the worst thing that could happen if my PS won't handle the extra stuff, along with the GB of RAM I plan on adding?
    San Diego, CA
    6,399
    Generally what will happen is you'd see system instability. If the PSU is overloaded TOO much one of two things could happen. A good quality PSU will just turn itself off, a cheaply manufactured one could fry itself, and possibly anything thats hooked up to it... That being said, Enermax makes good PSU's.
    Oct 2003
    Texas
    314
    ArcticFox,
    Wow, you folks sure like living dangerously
    Here's to hoping that you dont have problems, and just to give you something else to consider, scroll down to where they are discussing power supply issues for nforce 2 boards.
    Choosing the right power supply
    Scroll down on this one 2nd or 3rd paragraph
    GA 7n400pro
    XP2600m 12.5x200=2508.
    Chaintech 6600 Agp 256mb
    WD40,WD80,WD120 and Samsung 200 GB
    Frack brandon184's Avatar
    Wasilla
    11,195
    It'll work just fine.
  15. #15
    San Diego, CA
    6,399
    Originally posted by dafanman
    ArcticFox,
    I don't agree with what that guy is saying in the second link you posted... He's reccomending a 480 or better for a modern PC... You really don't need that much unless you're running a raid array of 15k rpm SCSI drives, dual processors and 4GB of RAM. My system which is fairly power hungry (specs listed above in previous post) runs perfectly stable on a 350 watt enermax.
  16. #16
    Jan 2003
    A theater near you
    5,424
    Yeah I won't be running anything really intensive, just one drive, a vid card/sound card and the usual stuff. I do overclock, and I haven't been able to get my 2500+ to more than a 3200+, even with a small voltage increase. My PS may have something to do with that, but I don't have a better one laying around to test it!
  17. #17
    San Diego, CA
    6,399
    Its quite common not to be able to go past 3200+, some can do it, but a lot can't... Which is why I always say, there is probably a good reason why 3200+ is the fastest Barton you can buy
  18. #18
    Member KarenMarie's Avatar
    Sep 2003
    Lyndhurst, NJ
    133
    this is what I just got delivered yesterday. I cannot wait to install it.
    I have:
    Gigabyte GA-7NNXP
    Athlon 3200+ Barton and cooling
    3x 512mb DDR 3200
    FX5600 256mb Graphics Card
    2x 120GB 72,000rpm HDDs
    Lite-on DVD -R/w +R/W
    Lite on CD +R/W -R/W
    Augidy Platinum EX
    KDS 17in LCD
    Altec Lansing #251 5.1 gamers speakers
  19. #19
    San Diego, CA
    6,399
    That should be a good system. Can't say I would have done the same though with that Barton 3200+... The fact that its more expensive than a P4 3.0C and performs under a P4 2.8C turns me off to it... Those 72,000 rpm hard drives should scream though!
  20. #20
    Sep 2003
    Lyndhurst, NJ
    133
    I have a P4 in my laptop and my daughter has one in the desktop she bought. I am not a big fan. I build approx. 5 systems a year.. i am such a tech pig. so this system doesnt seem overly fast unless I use someone else's system. Then I cannot wait to get home to mine!
    But i dont wanna hijack the thread. I am very excited to get the new PSU in this system. IT arrived yesterday, and with what i have read about it, I would recommend it to anyone.
