DVD burner won't burn  | | |
December 21st, 2003, 11:25 PM
| | Never forget
OK Here's the deal I went out and picked up another DVD burner for my main box. I installed it without a hitch and windows(win2kpro) shows it in DM and it reads fine. My problem lies with the burning software. It won't show up as a burning device in nero or Sonic MyDVD. I did Sony's test drive and it came back fine. What could I be forgetting about to get Nero to see it as a burner drive? BTW I have 5.5.8 installed right now and probably a newer version here some where.
GF4TI4600
K7S5A Pro
XP 2800+
1 gig of pc2700 DDR
160gig Mator
52x Liteon CDRW
Sony DRU-510A
16x Liteon DVD rom
Truepower 460w PSU
win2kpro |
December 21st, 2003, 11:31 PM
| | Did you try Google yet?
Update your Nero. It just doesn't have your drives info.
December 21st, 2003, 11:39 PM
| | Never forget
cr@p Nero list it as a non supported drive on there site  now what should I do for burning? |
December 21st, 2003, 11:49 PM
MDS,
Try downloading the Nero update to get to 5.5.10.54!!!! I just went thru what you did. Frustrating!!
When you get ready to burn it wants to burn just an image file to your hard drive, right??
Definitely upgrade to the 5.5.10.54 from the nero site & you'll be able to drop-menu to select your burner. Nero will give it a name like "ATAPI DVD burner". |
December 22nd, 2003, 12:09 AM
| | Never forget
downloading the nero 6 trial but there site does not list my drive as supported so I will see what happens. I did get Sonic MyDVD to work but I would like to use Nero. |
December 22nd, 2003, 12:22 AM
| | Never forget
It finds the drive but will only allow cdrw formats  Doesn't even give me the DVD options.
edit I may have found a way using express but will have to wait til tomarrow as I have to get some sleep to goto work(12hrs) in about 6hrs
December 22nd, 2003, 12:25 AM
| | Moderator
Have you tried contacting the vendor asking them what versions of the software should be used and such. Record Now MAX by Stomp software is a favorite burning app for DVD people. That may support your burner so its worth a look on google.
-: phenious :- |
December 22nd, 2003, 12:30 AM
| | Never forget
It came with record now DX I'll install it and give it a try tomorrow |
December 22nd, 2003, 12:34 AM
Don't do the Nero 6!! You'll have even more troubles there.
What you want is 5.5.10.54!!!!! If you have ANY version of 5.5 then the upgrade is available to you for free.
I had 5.5.10.4 and mine still wasn't recognized. Went to 5.5.10.54 and......voila!!! Done!! |
December 22nd, 2003, 07:31 AM
| | Never forget
Dooin' it I have 5.5.8.0 installed but where on there site can I find the upgrade? Everything I look at is trying to push there nero 6 package. |
