Results 1 to 3 of 3
    Senior Member eminem_rh25's Avatar
    Nov 2003
    Seattle, WA
    641
    Question USB on Comcast Box
    I have a 57 inch bigt screen TV. I just recently ordered a comcast HDTV Box. On the Front there is a USB 1.1 Slot right next to the A/V Jacks. WTF is that for??? I was wonderin if i could hook up my PC to there. Havent tried it yet
    Ultimate Member rpertusio's Avatar
    Nov 2002
    1,349
    From the manual of the HDTV box, it says:
    "There are also inputs for a Universal Serial Bus (USB), audio/video jacks and a Smart Card slot. These inputs are for
    future applications under development and are not enabled on this unit."
    - and -
    "USB - Not currently enabled - intended for future use."
    - rp
    Nov 2003
    Seattle, WA
    641
    Well I know i cant use it. Maybe next time i will read the manuel
