Results 1 to 15 of 15
Thread: Cooling Fans
    Nov 2003
    38
    Cooling Fans
    I am knew to this so bear with me. I am looking at a case that will allow the addition of 2 80mm fans. Some fans indicate they are for case fronts and some for case backs. Is there really any difference in how they are mounted? Should this be a concern?
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    The fans are the same, but front ones usually blow in and back ones blow out. It's all in how you mount them.
    Hard Sayin Not Knowin
    Nov 2003
    38
    can they usually be mounted either way? Is it best to have some blowing in and some blowing out?
    Jul 2003
    191
    they come so that they can fase in or out its not hard to switch them alll u need is a screwdriver, and fans arent specially made to face one way or another, hope that helps
    if u bought it change it if u cant buy it make it if u made it change it if u cant make it buy it
    1010011010 jmichna's Avatar
    Chicagoland IL
    3,249
    All the fans I've ever seen can be mounted both ways.
    "Normal" ventillation setup is to have one (or more) fans blowing (cool) air into case at bottom/front, and one (or more) fans drawing (warm) air out at the top/back.
    There are lots of variations, and some setups can get away with a single, exhaust fan at the upper/rear. Other rigs, especially folks with more powerfull CPUs and higher end video cards, add all kinds of intake and exhaust beyond the bottom/front+top/rear.
    Variations include a "blow hole" exhaust at the top of the case, a side panel "blow hole" bringing air in and blowing down onto the CPU and/or video card.
    Nov 2003
    38
    Thanks for the info. I'm pretty handy with tools so I think I make them work.
    Ultimate Member Starfury_2260's Avatar
    Aug 2003
    KY
    1,463
    the best idea would be too have an equal number of fans at the front (pulling air in) as the back (blowing air out). fans can be mounted either way. i've got 4 fans in my case and they work so well it heats up my room.
    Chicagoland IL
    3,249
    Talking
    Originally posted by Starfury_2260
    ...i've got 4 fans in my case and they work so well it heats up my room.
    Naw.... it's the CPU that heats your room
    The fans just move the heat out of the box... love those Athlons in the winter!
    Jan 2004
    Germany, Gauting
    106
    If your lookin for a case and cooling fans get an astak at least i think thats their name yea it is astak. They keep the chip and componets so cool that a intel 3.2ghz can perform at a massive 4ghz. I know it sounds impossable i thought so too but when i talked to a person online that was a sales man he told me it's how cold the case is. The case i was told keeps it at under -22 C which is frezzzzzzin. The case itself is 500$ though
    I chew wrigley's, what do you chew?
    Jan 2004
    Germany, Gauting
    106
    If your lookin for a case and cooling fans get an astak at least i think thats their name yea it is astak. They keep the chip and componets so cool that a intel 3.2ghz can perform at a massive 4ghz. I know it sounds impossable i thought so too but when i talked to a person online that was a sales man he told me it's how cold the case is. The case i was told keeps it at under -22 C which is frezzzzzzin. The case itself is 500$ though.
    Jan 2004
    Germany, Gauting
    106
    O sry about the double post hit the post button 2x. Sry
    Chicagoland IL
    3,249
    Try Edit... Delete Post... If that doesn't work PM a mod. Keeps the post count legit.
    Ultimate Member Urban_Squrill's Avatar
    Nov 2002
    Kalispell, Montana
    1,675
    Ah the age old question. To suck or blow?
    Urban is back.
    And yes that is how you spell my name. I am living proof that 2+2=5
    dontforget/rgdesb
    Aug 2003
    KY
    1,463
    i think alienware is refering to antec.
    jmichna- I KNOW THAT DUH...
    i wouldn't post another post about double posting (LOL), might get you in trouble with the mods. if you want to apoligize for double posting just edit one of the messages and replace the message with the apology.
  15. #15
    Ultimate Member Dax_Brandy's Avatar
    Manila, Phil
    1,699
    LOL
    if you are handy with tools, you can make a hole in the side panel and mount an intake fan there to blow directly to the system board.
    some also make a hole on top and put an exhaust fan in there to suck the hot air out. hot air rises in theory.
