Page 1 of 2 1 2 LastLast
Results 1 to 20 of 28
    Member Stealth_Sniper's Avatar
    Dec 2003
    NC
    53
    AIWA Stereo repair
    I have an AIWA 3 disk CD changer/stereo and whenever I put a CD in, it will pick up the CD but for some reason it won't spin the CD in order to read it. It sounds like it is going to start to spin, but then it dies out. Can anybody help me?
    Member mlee97's Avatar
    May 2002
    East Tennessee
    416
    Most likely lost a capacitor on the drive circuit... high tech fix... doesn't sound good.
    Dec 2003
    NC
    53
    That stinks, you think there is anything I could do to it though to get it running again? I know that taking it to get it fixed is the best option, does that cost a lot to get a capacitor fixed?
    Stealth_
    Ultimate Member RayH's Avatar
    San Francisco, CA
    2,799
    Depending upon how old the unit is, it might not be worth fixing. You'd be surprised how much electronics have dropped in the past couple of years!
    RayH42450@gmail.com
    Please indicate you are from TechIMO in subject line so you don't get deleted as spam :)
    Jan 2003
    Connecticut, USA
    816
    yes I have the same problem with mine...it spins the cd around for like 3 revolutions, then it stops. mostly with cd-r's though.
    my unit is about 5 years old.
    ~Branson ??
    I'm an Eagle Scout! (1997)
    Unhappy same problem
    Quote Originally Posted by StealthyV View Post
    ~Branson ??
    hey i have the same problem...i put in a cd-r or even the original disc but is won't play at all...so i dunno what to do...is there a way to fix it...right now it just sits in my room for decoration...i've had it for 4 or 5 yrs now...when i first got it, it worked fine but now it doesn't do anything. i sometimes use it to listen to the radio. please let me know if theres a way to fix it...thanks
    Nov 2008
    17
    It has probably just... died out.
    Smile AIWA stero
    Hi, I am having the same problem with my AIWA stero, it accepts the CD and spins it, but it does not read the CD. How can you help me?
    Do you have an address in san francisco?
    How much do you think it will coast me to fix it?
    thank you,
    Rocsana Ribeiro
    Healdsburg, CA
    13,875
    This was a known problem with the AIWA 3 disc changers. There was a class action lawsuit a few years back for the repair of the AIWA minisystems. The deadline for that though has long since past.
    Jun 2009
    16
    I have the same problem with my AIWA 3cd changer mini stereo system bought in 1998.
    The CD would spin about 3 times, as though the system reads it, but it will not play and spin consecutively.
    I thought a CD lens cleaner would solve the problem but it didn't.
    What sometimes helped me was actually banging on the top of the stereo system couple of times, like slapping it as soon as I see that it will not be read. Many times it would cause the stereo system to read the CD.
    But RayH is right, you could find some very cheap mini stereo systems with way better quality and ones that are compatible with iPods or USBs.
    San Diego, CA
    6,398
    Apparently this thread from January 1st 2004 refuses to die.
    Feb 2011
    thornbird
    Sounds as if that was a common problem. I also have a three disc changer.A cxna222 that hasn't been working for 4 years. Vintage 1998. After loading discs, it starts, spins for a few revolutions and then goes to the next, and then the next and then shuts off. The problem started with garbled sound and then gradually got worse. A cleaner didn't help. I love music so I bought a Sharp combo system. I too play the old one on tapes and radio. Anyone find a cheap fix?
    Sep 2011
    Smile romolus
    The fix is pretty easy once you figure out the problem.
    1) Remove the case and the back panel.
    2) With the backside of the stereo facing you, level your eyes with the back of the laser unit of cdplayer nd you'll see a small plastic screw which regulates a potentiometer.
    3) Plug the stereo on, insert a cd and turn the potentiometer really slowly until the laser is capable of reading cd's once again.
    4) Problem should be solved.
    Hope this helps
    Sep 2011
    Thumbs up Thank you!
    I have an Aiwa system from 1995 that had the same problem reading cds as this post indicated others have had. It was a great multi-audio system until a few years back. It's been collecting dust since. Today, ironically, one day after your post on how to fix, I decided I would do a quick Google search to see if there was an easy fix or if it was time to toss it since rapiring it would probably cost more than a new system.
    I ran into this thread and your post with the easy fix I was looking for....I gave it a try. I tell you what - I had more of a problem taking off the back panel and case and reattching it than I did following your instructions and fixing. Originally it took me a couple of minutes to find the plastic looking screw/potentiometer, but voila! There it was, I turned and tested and everything worked again beautifully. Like I said putting the case back together took me more time than the fix.
    I am so grateful to be able to restore a good thing to working order. Most of my music is on iTunes, but I still like to just toss on a few (old) cds that will play back to back while I'm working around the house, so I'm thrilled!
    Thanks again!
  15. #15
    Feb 2012
    Quote Originally Posted by romolus View Post
    Hope this helps
    The problem I've got is that the 3 cd changer does not seem to be aligned properly. It randomly mis-aligns itself and so when each cd lodges itself in the laser bay it is not seated properly and fails to rotate.
    Any help would be great.
    Cheers
  16. #16
    marko van burno
    i have an aiwa hifi but it only works when it wants to if it gets to hot it switches itself off when it comes on its on for like 2 mins then switches off ive been told it is a eco chip failure but can that be fixed if anyone knows of anyone that can fix it would you e-mmail me at medion_21@yahoo.co.uk its a shame to just bin it. it has lovely sound and pisses my neighbours off lol
    its a aiwa xh-a1000
  17. #17
    Feb 2014
    0
    I found out the problem. Take off top lid have tray sticking out and there's a white cover over the lazer. Just remove it with sisccors. And it work fine.
  18. #18
    If you can take the top off of unit and the moment the disc loads and tries to spin go ahead and help it! If it starts playing its you spindle motor, if not its the laser!!
  19. #19
    May 2015
    I have a aiwa desk top. I can hear the cd playing thru the speakers really low but cant get it to turn up or nothing. Is something blown. Like maybe the amp?
  20. #20
    hello my friend is always the laser lens or pickup you buy a new one and replace it and they are not very expensive do not forget to put antistactic wristband when you are replacing the laser lens,good luck my friend.
