Thread: Webpage Design
January 5th, 2004, 08:40 PM #1
Webpage Design
Why is it when I go to www.newegg.com or any other website it fits perfectly in the screen no mater what resolution I look at it. But yet when I made my website I looked at it in 1024x768 and it was off the screen and I had to scroll over. Is there a way to fix this and I dont have anything bulging out to the side.
January 5th, 2004, 09:03 PM #2
The use of tables set with percentages works well. That way the end users machine will scale the page.
Cheers!
January 5th, 2004, 09:09 PM #3
Oh! And when designing, set your screen resolution to 800X600.
Cheers!
May 3rd, 2008, 09:49 PM #4Junior Member
- May 2008
- Location
- N. of Mex, S. of Can
- 15
Shadow - Beemer's answer is the correct one.
One way to find out is to look at the source of a site you want to mimic some element of. to see what they are doing to accomplish it.
I hope this is helpful.
hb93
Taking advice from you would be like accepting a dinner invitation from Hannibal Lecter -- with the difference that he's smart. How's this? When I took the course several years ago, I discovered...
Happy Sequester Furlough Friday!
