stupid card reader
Currently Active Users: 1638
Discussions: 200,933, Posts: 2,379,179, Members: 246,298
Old January 25th, 2004, 11:43 PM   Digg it!   #1 (permalink)
nochay's Avatar
Send a message via ICQ to nochay Send a message via AIM to nochay Send a message via Yahoo to nochay
Angry
stupid card reader
I got one of those Compaq keyboards from AMEX with the keyboard mounted smart card reader, and the damn thing isn't working. I have tried many different things, and it still won't run.
I get a error from a program called Gemplus SmartDiag 2.0 saying that the install of Microsoft Smart Card Base Components is corrupt.
I also get this from a device called Grserial:
Cannot create more device.
and this:
The GrSerial service failed to start due to the following error:
The system cannot find the device specified.
what is going on? This is pissing me off, and not making any damn since. trying to install this thing on a windows 95 computer just resorts in a stupid "network connection not allowed" or some dumbass error.
I give up. What is going on? Do I need these microsoft smart card base components? does anyone have anything better then that?
Windows 2000 professional is my O/S.
Dane
Back Online! http://rhd.dyndns.org <-- The History Site (Admin)
http://www.vegasfreecyclers.com/forum/index.php <---Moderator
nochay is offline   Reply With Quote
Old January 25th, 2004, 11:46 PM     #2 (permalink)
crystaldragon's Avatar
Send a message via Yahoo to crystaldragon Send a message via Skype™ to crystaldragon
Are you certain you have the up-to date-software for the device? I always try to get the latest drivers from the manufacturer before I try the packaged ones.
Have you check Microsoft Update?
Those who cannot remember the past are condemned to repeat it
crystaldragon is offline   Reply With Quote
Old January 25th, 2004, 11:50 PM     #3 (permalink)
nochay's Avatar
I'll check microsoft update, and that is it. Mucking around on the compaq/hp/third reich site does not bring up anything. I can't find updated drivers on hp's worthless site.
Nothing is even mentioned about the keyboard on the site, except for a feature document.
Dane
Old January 26th, 2004, 05:02 AM     #4 (permalink)
Banned
Send a message via AIM to Crazed Modder
Maybe it beacause your comp isnt a cash register and it doesnt recognise the money prog that it needs
Crazed Modder is offline   Reply With Quote
Old January 26th, 2004, 11:20 AM     #5 (permalink)
If you want to post the model number of the keyboard I'll take a look around and see what I can find for you.
Crazed Modder
A smart card is a type of flash memory card like compact flash or secure media. Not a magnetic stripe reader.
JD
Old January 26th, 2004, 04:01 PM     #6 (permalink)
nochay's Avatar
Hey JD,
Model: SK-3320
Compaq P/N: 115505-006
that is what is on the bottom of the keyboard.
Thanks for your help!!! Windows update didn't have anything either for it.
Dane
Old January 26th, 2004, 08:12 PM     #7 (permalink)
nochay's Avatar
problem fixed. my smart card drivrs and things got corrupted. thanks for your help JD!!! Does anyone know of any software that could interface with the kinko's cards? I want to make them a security card or something.
Dane
Old January 26th, 2004, 08:41 PM     #8 (permalink)
Glad to hear you got it working nochay.
I did find out that reader is configured from the factory to use com port 1 only. The reason you got the weird error in the W95 machine is that it is totally unsupported.
Old January 27th, 2004, 01:25 AM     #9 (permalink)
Banned
oooops i misunderstood what he was saying I forgot all about camera cards
My bad
Is It Just Me? (2878)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
Wireless Televisions. (2)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
