Results 1 to 6 of 6
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,194
    4
    MS power point..
    Hey all, I'm run into a problem.
    For my project, I need to do a power point, (or something alone those lines) to present it to the class.
    I don't have M$ Power Point and I am wondering are there any free programs that can take it's task?
    Also, the computer I will be presenting it on does have M$ power point, so I would also need a program that can possibly open it with that? I'm really lost as to what to do....
    Mar 2002
    Under Your Bed
    8,909
    OpenOffice (100% free) has a feature called 'Impress' which is comparable to Powerpoint.
    PowerPoint vs. Impress
    Nov 2004
    Burning in Florida
    15,194
    4
    is it possible to use open office files on power point? like use power point to display them
    Thanks btw
    Mar 2002
    Under Your Bed
    8,909
    Honestly, I don't know...I've never tried that. I know that it works the other way around...in fact, when you install OpenOffice you are given the option of handling Powerpoint, Word, and Excel files.
    Senior Member teengeek88's Avatar
    Jan 2004
    NW burbs of Chicago
    838
    i believe you can save them as ".ppt" files
    Nov 2004
    Burning in Florida
    15,194
    4
    yes, apparently I can save them as that.
    Thanks for the help, your a life saver Mar! (aka a mix of procastination on my part, and a 10minute speech/presentation)
  1. Power Point question
    By Wombat in forum Applications and Operating Systems
    Last Post: October 26th, 2003, 07:33 PM
  2. Long range point 2 point wireless network
    By implexant in forum Networking and Internet
    Last Post: October 13th, 2003, 08:11 PM
  3. Power Point help
    By ZENYO in forum Applications and Operating Systems
    Last Post: April 17th, 2003, 12:10 PM
  4. Power Point Themes
    By NDuser in forum Applications and Operating Systems
    Last Post: December 2nd, 2001, 07:33 AM
