Need Urgent Help with Graphics card
Currently Active Users: 2436
Discussions: 200,941, Posts: 2,379,274, Members: 246,304
Old September 10th, 2004, 09:52 AM   Digg it!   #1 (permalink)
I just installed a new PSU successfully to power my new Radeon 9800 pro. Afaik i uninstalled the old drivers took the old card out put the new card in and went to install the drivers...but it didn't get past the windows loading boot screen. It just went black after that. If it is a conflict with the old drivers how can i resolve it? otherwise how can install the new drivers without loading windows.
Thx in advance...this is kind of worrying
Tech0rz is offline   Reply With Quote
Old September 10th, 2004, 09:59 AM     #2 (permalink)
if u didnt get past the windows loading screen, its most lightly due to not enough power.
tell us your PSU specs and your previous PSU & graphicsit would help alot
edit:
ok i just read your previous post
if according to your specs there, 450W should have absoultely no problem despite 9800 pro being a mid-range power-hungry card. (6800GT are high-end power-hungry cards )
check your psu connections and check any abnormalities in your BIOS
mezdog is offline   Reply With Quote
Old September 10th, 2004, 10:18 AM     #3 (permalink)
tbh i think everythin is fine with the bios, what happened was when i attempted to uninstall the old drivers, i then restarted, and even with the old card in windows XP wouldnt load up. i then put the new card in to see if it would work...being plug and play i thought there wud be no prob...again didn't get past boot screen.
what i'm thinking is i've disabled the thing instead of uninstalling the drivers
if that is the case how could i resolve it?
Old September 10th, 2004, 10:22 AM     #4 (permalink)
hav0c's Avatar
Was your previous card a nvidia one? If so try a driver removal tool like this one
http://www.majorgeeks.com/download.php?det=3233
hav0c is offline   Reply With Quote
Old September 10th, 2004, 10:22 AM     #5 (permalink)
see if u can enter windows in safe mode (f8)
if not, reinstall windows. (format)
if u dont want to do that, wait for more professional help.. hm
Old September 10th, 2004, 10:28 AM     #6 (permalink)
hav0c - this looks promising, but is it possible to even run this without Win XP loading up...cos thats one thing that the pc won't do is load XP...i can get to bios and recovery console but not windows itself...if u can do it however would u quickly tell me how pls?
Old September 10th, 2004, 10:52 AM     #7 (permalink)
:slack: strong
Detritus's Avatar
Send a message via MSN to Detritus Send a message via Yahoo to Detritus
Can you get into safe mode, if so, install and run that driver removal utility from there.
Tyranny doesn't have to come at the end of a gun.
It also comes cloaked in compassion.
Detritus is offline   Reply With Quote
Old September 10th, 2004, 11:00 AM     #8 (permalink)
no i couldn't get to safe mode...but theres been an advancement (or should i say a step backwards ) i used last known good config...and windows is now loading...so i can use the tool hav0c suggested to uninstall the drivers properly and then give it a go.
Old September 10th, 2004, 11:04 AM     #9 (permalink)
all the best Tech0rz
help... WAKKA2223 Graphics Cards and Displays 30 August 7th, 2004 10:52 AM
very very n00b Microsoft_Works? Graphics Cards and Displays 9 July 14th, 2004 08:26 PM
AMD Thoroughbred on A7M266 bicky Processors, Memory, and Overclocking 10 September 28th, 2003 02:46 PM
Graphics or video (poll) wackoguy Graphics Cards and Displays 11 June 30th, 2003 08:51 PM
Tv Tuner troubles ben-the-slacker Graphics Cards and Displays 9 May 26th, 2003 03:24 AM
Is It Just Me? (2915)
Wireless Televisions. (8)
Regular Build (6)
Obama the Muslim (14)
screen resolution vs monitor size (1)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
