HDTV - best card to connect pc to hdtv via component cable
Currently Active Users: 2257
Discussions: 200,937, Posts: 2,379,253, Members: 246,302
Old September 27th, 2004, 09:28 PM   Digg it!   #1 (permalink)
Man,...these cards business is tough...
buiding a pc should be easier ..\
anyway..i want to get best possible display on my hdtv using component cables...
which card would fit tthe bill....
or should I buy ati card with ati vga to componet adapter..
or maybe a vivo card....
poof...ma head's spinning
fkdoc is offline   Reply With Quote
Old September 27th, 2004, 10:06 PM     #2 (permalink)
Jarhed7276's Avatar
The ATI 9800 AIW comes with a RGB connector for HDTV. You you can just buy the connector but I not sure about what graphics cards it works with.
ATI is or has come out with an HDTV card, too.
Jarhed7276 is offline   Reply With Quote
Old September 28th, 2004, 09:01 PM     #3 (permalink)
Lightbulb
...but RGB connector won't work with component RCA cables mate...
Isn't there a decent graphic card (affordable ) out there with rca Component males on other end...
OR....how abt VIVO....if u r getting component wires through vivo port ... how's the quality...heh
Old September 28th, 2004, 09:07 PM     #4 (permalink)
Onii-san
Bizkitkid2001's Avatar
If your using an HDTV you don't want to use RCA cables, you want to use RGB, not Red yellow white RCA.
Bizkitkid2001 is offline   Reply With Quote
Old September 28th, 2004, 09:19 PM     #5 (permalink)
hmmm...interesting..
my hdtv has component in, s-video in and AV in...
there's no DVI in...but that wouldn't have worked anyway ...
and this RGB.....i have no idea about that..
my HDTV is samsung 47'
Old September 28th, 2004, 10:08 PM     #6 (permalink)
Onii-san
Did you check the back of your tv? My TV is a HDTV and the high def connections are in the back, not the front.
Here are some pics of what the connectors look like
http://eddie.dyec.com.tw/diy-product...e/rgb_wire.htm
Old September 28th, 2004, 10:15 PM     #7 (permalink)
erhan28's Avatar
Send a message via MSN to erhan28 Send a message via Yahoo to erhan28
WoW extreme Cables! that is hard cables it must be expensive though..
MSI K8N Neo4 Platinum / A64X2 4800+ Toledo(Stock)
7900GTX 698mhz / 2GB Corsairs XMS PRO Dual
Hitachi SATA II (2x 250GB, 1x 500GB)
ASUS G1
erhan28 is offline   Reply With Quote
Old September 28th, 2004, 10:52 PM     #8 (permalink)
my HDTV has this connector for hdtv signal
(Y,Pb,Pr) 2 1080i/480p/480i
And I just need the best video quality from my PC on this HDTV as I intend to use it instead of a monitor...
I need a graphic card to go with the picture.
Old September 29th, 2004, 10:20 AM     #9 (permalink)
Jarhed7276's Avatar
Y,Pb,Pr is another name for RGB (which stands for Red, Green, Blue). The link below is for ATI's adapter. ATI says that it will work with the 8500 on up. I would think, but don't know, that it would work with any card that has a DVI-I interface.
http://www.ati.com/products/hdtvadapter/index.html
Old September 29th, 2004, 09:30 PM     #10 (permalink)
Thankyou my friend for the ATI link.
btw....RGB is NOT same thing as Y,Pb,Pr.....
RGB connector had 5 rca connectors H+V.....
but any opinions abt graphic cards with VIVO....they have component output through vivo out......does anybody know abt their performance and graphic quality.,...
DVD Player KLH KD-1220? enuff1 General Tech Discussion 2 September 5th, 2004 12:57 PM
Help with my ATI HDTV Vega to Component Adapter lukesparksoff Graphics Cards and Displays 3 August 19th, 2004 01:54 AM
viewing HD video maface Multimedia and Audio 0 June 17th, 2004 11:40 AM
PC on TV...How good? soad1789 Graphics Cards and Displays 16 February 23rd, 2004 02:43 PM
S-video vs. Composite Overclocked412 General Tech Discussion 12 February 21st, 2004 07:57 AM
Is It Just Me? (2907)
Wireless Televisions. (8)
Obama the Muslim (14)
Have you switched yet? (85)
Regular Build (4)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
Optical Audio A-B Switch (1)
