Join TechIMO for Free!
Thread Tools
Currently Active Users: 2873
Discussions: 186,667, Posts: 2,227,676, Members: 230,314
Old December 22nd, 2004, 07:41 PM   Digg it!   #1 (permalink)
pinipig523's Avatar
Xbox to connect to my Samsung LCD monitor
I know sometime ago, I asked this out of curiosity but I'm for real now (since Im getting an xbox). I want to connect an xbox into my computer's lcd but I forgot what I need to buy to do this.
So, linkys please?
Thanks much!!
pinipig523 is offline   Reply With Quote
FREE instant scan
Old December 23rd, 2004, 02:27 AM     #2 (permalink)
pinipig523's Avatar
I just found out that my tv tuner (inside my pc) has a component video in (not s video)... has anyone tried feeding video (like from a console or dvd player) into their pc via something similar to this and had it successfully pop out onto the computer monitor?
I guess my underlying question is: Will it work?
Old December 23rd, 2004, 02:33 AM     #3 (permalink)
jmebonner's Avatar
www.x2vga.com
HAd one, works perfect. There are some cheaper, but none better, imho.
jmebonner is offline   Reply With Quote
Old December 23rd, 2004, 02:33 AM     #4 (permalink)
it should altough im not sure what you use to view it... usualy those ports are for capturing video but idk
AMD 64 3400+ 2.2 @ 2.31
Corsair value select 1 gig
DFI Lan Party nForce 3 250gb socket 754
WD ide 7200 caviar 120gb
Radeon 9250
italiamodena575 is offline   Reply With Quote
Old December 23rd, 2004, 02:36 AM     #5 (permalink)
Perfetc Member
VHockey86's Avatar
It will work perfectly fine.
Your Composite/S-video connections arent going to be any different than if you were watching TV through the coaxial connection on your computer.
I've had my xbox hooked up to my computer quite a bit without any issues.
I was working on a morrowind website at one point and hooked my xbox up to my computer to play/obtain screen captures for the site.
what I used:
http://leadtek.com/multimedia/winfas..._deluxe_1.html
VHockey86 is offline   Reply With Quote
Old December 23rd, 2004, 02:41 AM     #6 (permalink)
jmebonner's Avatar
It'll work, but you won't be able to take advantage of the much higher vga resolution (almost hd-quality).
Old December 23rd, 2004, 02:44 AM     #7 (permalink)
Perfetc Member
VHockey86's Avatar
Definately true... but if you're going to goto the expense of buying an adapter like that (especially when hes already got a tv tuner), you mide as well be PC gaming.
Old December 23rd, 2004, 04:39 AM     #8 (permalink)
pinipig523's Avatar
Thanks for the tips so far guys!
JME... that vga converter looks promising except that it works only for the xbox. I'm afraid that when I get a new console in a year or two, it wont work with it.
VHockey... nice to know it works! =)
I was wondering though, what do you guys mean by it wont display at HD quality? How is this possible if I set my monitor beyond HD settings (i.e. 1280x1024)?
VH... in your experience, is it better to leave the monitor set at 1280x1024 or have it set to standart VGA resolutions (640x480)?
Old December 23rd, 2004, 09:24 AM     #9 (permalink)
Perfetc Member
VHockey86's Avatar
Well, the signal is only of a TV resolution, therefore you wont be receiving anything better (HD) on the monitor. Your xbox is going to think its connected to a regular TV.
You can leave the monitor's resolution up higher. Whatever software you have for your TV tuner should allow you to resize the window. Just adjust it so that the picture quality / size ratio is good enough for you.
I normally just had a fairly full window at 1024x768 and it looked fine, but then again I was just playing morrowind, not a FPS, so seeing everything all the time wasnt that critical.
Old December 23rd, 2004, 03:06 PM     #10 (permalink)
pinipig523's Avatar
How do I make the xbox think that it's connected to an HD monitor and not just a regular tv?
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
NEED SOME SERIOUS HELP PLEASE Laptop wont boot War Mobile Computing 23 December 26th, 2006 01:17 PM
How to display console system on monitor? pinipig523 Graphics Cards and Displays 4 November 1st, 2004 01:39 PM
How I can connect XBox to my media PC Zsuzsa Multimedia and Audio 3 April 19th, 2004 02:00 AM
LCD Monitors vesther Graphics Cards and Displays 18 November 18th, 2002 02:49 PM
Is It Just Me? (626)
Bought an AGP "HIS Radeon HD 3.. (18)
Presario Help (6)
Misery Loves Company... (1861)
Folderchat: The Holiday thread (156)
Putting together my wish list (14)
RAID 0 External Drive Slow/Failing .. (17)
Incorrect Amount of RAM Listed (8)
First Time PC Builder (14)
is this a good overal gaming la.. (0)
Is this a good laptop for gammi.. (1)
Outlook add-in won't remove. (3)
RAM Upgrade (8)
Need to retrieve files from a v.. (6)
I7's power supplies (0)
Bought an AGP "HIS Radeon .. (18)
2 laptops into 1 (1)
Presario Help (6)
