January 20th, 2005, 09:30 PM
| Major Artifacts in 6600GT!!! Help plz~
Ok...im so confused now....i just got my new Leatek WInfast 6600GT. I installed it and i get major artifacts when i ran 3dmark03...samething applies to when playing any games. So i used driver cleaner3, updated SIS AGP, lowered my CPU down b/c i thought it was my cpu, and many more. Can any1 help me solve this?
Live Fast, Die Young, Dont Forget, Dont Regret
January 20th, 2005, 09:32 PM
Try the 67.03 driver there supposes to be good. If that does not work then it might be a bad card my first 6600GT was the same. http://www.nzone.com/object/nzone_do..._2k_67.03.html
This is a 67.03 driver release note:
The issues that some users have reported seeing when using the GeForce 6600 GT AGP are due to a driver bug which causes 3D corruption when this GPU is used with certain motherboards, most notably SIS motherboards. The fix is included in this release.
January 20th, 2005, 09:35 PM
January 20th, 2005, 09:54 PM
wow thx! neo u saved my life lol
Ok i got another favor to ask
I'm all set with the artifacts. i'm artifact free now lol
but i still got radlinker installed and cant uninstall it
When i try it tells me its missing radlinker.msi and tells me to redirect path to the folder that contains the file. Does any1 have the installation file? or any other way to uninstall it? |
January 20th, 2005, 09:57 PM
hmmm, reinstall it and then try to uninstall it maybe? Not really sure this is the first time iv heard of the program. Ill have a google around for you  |
January 20th, 2005, 09:59 PM
thx neo....
I already tried that tho lol |
January 20th, 2005, 10:08 PM
looks like radlinker.msi got deleted when you updated drivers. reinstall radlinker then uninstall your drivers and radlinker in safe mode then install the new drivers without the radlinker. |
January 21st, 2005, 11:46 AM
Well...the problem is i dont use 9800xt anymore so i cant install the drivers or the radlinker.... any other suggestions? |
