Thread: help!! nned advice
April 7th, 2005, 02:46 PM #1Junior Member
- Mar 2005
- 29
help!! nned advice
i m lookin for a graphics card which is compatiable with all 3d games. right now i hav nvidia riva tnt 2 32 mb ram (i think) but still games like hitman2 & doom3 r slow. i hav the min/recommened requirements of the games but not right now...but i m sure that the recommended reqts are 64 mb,i want to buy a 128 mb right now but can any1 suggest which 1 should i buy?
i m thinking of buying nvidia 128 mb card. i hav heard the nvidia is the best n most compatiable car (please correct me if i m wrong) so i m planin 2 buy a 128 mb nvidia card, is that the best 1? & i m not using my pc for any profesional use, its just personal use, please help all !!! I want 1 which is compatiable for all teh latest games
April 7th, 2005, 02:49 PM #2
can you list your current system specs and your available budget for buying the card?
April 7th, 2005, 03:01 PM #3
if your mobo supports a PCI-e card, and you have atleast 180 to spend, buy a MSI PCI-e nVIDIA GeForce 6600GT at newegg, you get three games with it, it's a very high-quality card and has the ability to play Doom 3 perfectly, also if it's laggy buy some more ram.
RIP TKOP!!
April 7th, 2005, 03:03 PM #4
yes , specs on your system would be good.. like the type of cpu you are using, how much ram you have, your operating system...
just saying your going to buy a 128 nVidea card doesn't really make it clear to us on how much you want to spend and what you are thinking of buying...
I will say this, since it looks like your using an "Older" vid card, any new card would be an approvement...
to play Doom3 and modern games with good detail, you most likely would need a
nVidea 5600 Ultra, 5900, 5900XT, 5900 Ultra...
some older cards like the Ti4200, Ti4600, Ti4800 128MB might still work decent... but are DX8
or a "new" card would be a nVidea 6600 or 6600GT 128MB... but price wise, your looking to spend about 130-200 on one of these cards... but they will play Doom3 at high settings very smoothly... (depending on your PC specs)
here is a link to a chart for FPS (frames per second) running Doom3 on high settings... take a look at it, some cards are ATI and some are nVidea... then price out the cards in your budget..
http://graphics.tomshardware.com/gra...charts-07.htmlLast edited by sweeper2; April 7th, 2005 at 03:06 PM.
April 7th, 2005, 03:24 PM #5Junior Member
- Mar 2005
- 29
doddsy i hav P4, 2.80 Ghz, 256 MB RAM... & yes i m gonna make my RAM 512 Arenal & i dont mind spending a bit high coz i love videogames lol
& nVidea 5600 Ultra, 5900, 5900XT, 5900 Ultra... r they all 128 mb ram coz i think the MBram makes the most difference right?
April 7th, 2005, 03:47 PM #6
ANNNNND.......
Its not always as simple as just slapping in a card...
The power supply requirements have to be met as well...
If this is a Compaq, HP, Gateway, etc... then you can almost forget about a decent upgrade..
You might want to look at the ATI 9800 with 256Bit and 128MG ram...
and yes you do want a decent amount of MB ram, but in general the Video ram is actually more important for gaming
April 7th, 2005, 04:16 PM #7
well, i found out with Doom3 , i had 512MB ddr400 ( 2X 256MB) Mushkin blue in dual channel... with a 5900XT 128MB Leadtek... it played ok, but still a little sluggish running "HIGH SETTINGS"...
I switched my ram to (2 X 512) ddr400 and kept the same card... and the difference in playing the game was huge... i put it on ultra settings 1024X768 and played really well, only a slight bit of lag.. under "HIGH SETTINGS" it played great...
so system ram can make a difference.. if you stick with just 512MB (by the way, what speed is it ..? pc2100 , pc2700 , pc3200 ??) i would look at a good top end card like a 9800Pro (ATI) or a nVidea 5900 or 5900 Ultra (128MB) or looks as though you can put in a 6600GT AGP card... that would be a good choice if you have the money.. but still would up your system ram to 512MB...
April 8th, 2005, 08:04 AM #8Junior Member
- Mar 2005
- 29
on my pc i dont hav the option of 1024X768, all i get is 600x800,640x840 & 1 more which i cant remember...& i cant beleive its so difficult 2 just play doom 3 smoothly, i really hate wen games r slow, i really really hate that so i wana sure it doesnt happen if i play doom 3
already hitman 2 is slow & i hate it! but prince of persia 3d & UT worked fine
as far as i think (i will hav 2 check min requirements again) doom3 should work very smoothly with 128 mb card & 512 MB ram
& i guys i dont hav much tech knowledge about graphics card/rams but i know the basics though so it may take me a while 2 figure out wat u said lol n i ll replu later 2 that
i really appreciate all the posts made by u guys & i hav a lot of questions which i ll b askin later!
April 8th, 2005, 08:16 AM #9Junior Member
- Mar 2005
- 29
so ideally any game should run very well with 128mb ram of graphics card & 512 mb ram ??
April 8th, 2005, 10:14 AM #10Junior Member
- Mar 2005
- 29
anyone??
April 8th, 2005, 10:20 AM #11Generally, that is true for today's games.
Originally Posted by watever
However, some 128MB cards (e.g. Nvidia MX440) may as well be 32MB as it is a very low performance card.
Also, there are different kinds of ram so 512MB SD RAM is not the same as 512MB of DDR RAM.
What is the model number of your motherboard? That'll tell us what kind of graphics card and RAM you can do?
This'll help
http://www.lavalys.com/products/down...ng=en&pageid=3
April 8th, 2005, 10:42 AM #12Junior Member
- Mar 2005
- 29
right now i hav 256 DDR RAM but i ll upgrade it to 512 DDR RAM, i hav a NVIDIA RIVA TNT @ model 64.. 32 MB graphic card but... when my pc boots up it shows me as 32 MB ram card but wen i see it on device manager on the nvidia properties it tells me its 16 MB now thats really fishy,but i mpretty sure its 32 also 16 is the normal graphics card or the basic card most pcs have so i m pretty sure its 32 mb graphics card & iwant 2 upgrade it to 128MB ( or shouldi upgrade it to even higher?)
April 8th, 2005, 10:59 AM #13
Dont look for the raw specs. You have to look for a faster GPU. Right now, 128mb is good enough. Only game that takes advantage of 256mb is Doom3. Of course 256mb is future proof. But i suggest u to get atleast 512mb ram and maybe buy ATI Radeon 9800PRO or 6600GT if u want to spend some more money. Dont buy any of the FX series b/c they are horrible in DX9 games which are the games now we're playing.
Live Fast, Die Young, Dont Forget, Dont Regret
April 8th, 2005, 11:06 AM #14Install this software. It'll tell you everything you need to know
April 8th, 2005, 11:24 AM #15
You would probably get more help if you made it easier for us to read what you are saying.
No, 128 MB graphics card is fine.( or shouldi upgrade it to even higher?)
April 8th, 2005, 12:11 PM #16
We still dont know how much u want to spend. IF 200 is max get a stick of 512mb ram and a 9800pro. I u can spend more get that stick of 512mb ram and a 6600GT,
3.2ghz HT P4
1024kingston DDR2
ATI 9800pro 256mb
160gb sata raid hd
April 12th, 2005, 12:10 PM #17Junior Member
- Mar 2005
- 29
thanku for all the info guys, yes night i hav 256 DDR RAM now & I am going to upgrade my RAM to 512 DDR RAM
are ATI Radeon 9800PRO or 6600GT both made by nvidia?
i m not confused about my computer MB RAM i m gonna increase it to 512 MB RAM but i m really confused about the card coz there r so many graphics cards available, right now i m thinkin of puchasin ASUS nVIDIA GeForce 6800 Ultra Video Card, now i hav gone thru the requirements but i m not sure if its compatiable with my pc, i dont know about my bus,power supply but i ll try 2 find it on my own.
i have 2.8 Ghz ram,my RAMs gonna be 512 MB RAM & I have pentium 4
so every game should work fine with ASUS nVIDIA GeForce 6800 Ultra Video Card riright?? & i beleive its theexisting best card right? according to http://graphics.tomshardware.com/gra...arts-07.html??
April 12th, 2005, 12:30 PM #18
x850PE beats the 6800ultra by alittle. And im sure u would have to upgrade PSU to run a 6800Ultra cause think drinks voltage. And unless ur a extreme,super extreme gamer a 6800ultra isnt really nescassy unles u future proofing.
I i was u id save some money get a gig of ram and 6600GT. That could run any game now and later on highest settings.
And the 9800pro is ATI.3.2ghz HT P4
1024kingston DDR2
ATI 9800pro 256mb
160gb sata raid hd
April 12th, 2005, 04:22 PM #19I agreed, get 1G ram and 6600GT.
April 12th, 2005, 05:42 PM #20Unregistered
- Apr 2003
- 423
buy the ATI Radeon 9550
it's like $120 @ bestbuy
256MB DDR AGP 8X
Need advice on giving advice.
By Hungrycookpot in forum IMO CommunityReplies: 0Last Post: July 6th, 2004, 12:20 AM -
need advice help
By sao95 in forum Graphic Design and Digital PhotographyReplies: 2Last Post: April 27th, 2004, 09:40 AM -
hi im new here n need advice
By Legend107 in forum MotherboardsReplies: 9Last Post: July 9th, 2003, 11:38 PM -
need advice
By merv62 in forum Graphics Cards and DisplaysReplies: 5Last Post: February 21st, 2003, 02:00 AM
Best wishes for your wife, TP. I hope it all turns out OK.
