Problems using Sharp LCD TV as PC Monitor
Currently Active Users: 2099
Discussions: 200,948, Posts: 2,379,384, Members: 246,309
Old July 16th, 2005, 11:26 AM   Digg it!   #1 (permalink)
Question
I have a Sharp LCD TV (LC-26GA5U) and my graphics card is e-GeForce 6200. The Sharp LCD is connected to the graphics card using a DVI-I cable. I also have a regular computer monitor (Gateway FPD1730) which is connected to the card with a VGA cable. I am using windows XP.
When I boot the system, both screens display the BIOS information and the Windows XP loading screen, but when it gets to the blue Welcome screen, the Sharp LCD goes blank but the other monitor continues to display.
When I remove the Nvidia driviers (I am using the newest drivers available on Nvidias website), I am able to see both monitors all the way through startup and regular use, but they are cloned (displaying the same thing, in the same resolution on both and only one monitor appears in the Windows "Display Properties" dialog.
Ideally, I would like to be able to use the LCD TV as a second monitor to extend the desktop (Nvidia's nView would be great for this if it worked...)
Any help would be appriciated. Thanks
zubanhunter is offline   Reply With Quote
Old July 16th, 2005, 04:21 PM     #2 (permalink)
Greetings, and welcome here!
Seems we got a case of failure to RTFM
You need to tell the Windows driver what to do with the 2nd unit. A visit to Display Properties is in order, maybe even to NVidia's extensions to it (under "Advanced"). There, you'll be able to set the desired mode (single, clone, twin, extended desktop, whatever), and in case of ext. desktop, then teach Windows your physical monitor arrangement.
Peter M is offline   Reply With Quote
gateway 2500 no video on lcd but monitor out shows on desk top monitor stonecraig Mobile Computing 0 November 13th, 2004 06:56 PM
What to look for in a lcd monitor rickytim Graphics Cards and Displays 8 October 16th, 2004 08:30 PM
LCD Monitor - yes or no? lauroy8 Graphics Cards and Displays 16 June 11th, 2004 11:46 PM
Need LCD Monitor Help ragtop Graphics Cards and Displays 16 December 29th, 2002 11:03 PM
Which LCD Monitor? 5atanic Graphics Cards and Displays 0 December 27th, 2002 12:41 AM
Making Health Care Worse (169)
The disrespect of Obama by Russian .. (20)
Is It Just Me? (2934)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Internet Lost (0)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
