Results 1 to 8 of 8
    Oct 2005
    4
    6600 GT OC Installation problem
    Hi,
    I am trying to install BFG 6600GT OC PCIe. When I bootup I get corrupted video with heavy pixellation of various colors. In background I can see vague outlines of icons.
    Before I installed I used all the precautions and grounded myself to prevent static.
    Also when I replace the 6600gt with ati x300se td 128mb pcie, the system boots fine and everthing is ok. The display is fine with ati x300se.
    The problem is only with 6600gt.
    My power supply is 300W.
    Any input is appreciated.
    Aug 2005
    151
    Sounds like BFG may have overheated your card in the OC process, I would send an E-Mail to wherever you bought it from and ask for a replacement. I would also get a new power supply, just because for any newer graphics card you should have at least 400W.
    Desktop: Athlon X2 4200, 2GB, 768mb GTX460, 320GB
    Laptop: HP Dv6: Phenom II n930, Radeon HD4250 + Radeon 5650, 4GB, 500GB
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,443
    especially if its a generic 300W PSU... then u definately need a new one...
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
    Oct 2005
    4
    My power supply is from HP
    My computer is HP Media center m1070n with 300w psu (merlot, regular B)
    No clue what that means ?
    What do you guys think of Ultra X 500W psu with +12V @ 34A at outpost.com
    Aug 2003
    Madison, WI
    15,225
    No way...I would not buy an Ultra X psu...get a good brand...one that is very reliable...like this on:
    http://www.newegg.com/Product/Produc...82E16817104953
    EDIT: Welcome to TechIMO btw.
    ...and I don't know about your media center...I don't know if it supports an atx psu...
    Warsaw, Poland
    6,443
    Ultra X PSUs SUCK....
    Thats why you dont buy brand name computers... all they do is cause problems when trying to upgrade... they're like Macs... once they're old you throw them away and get a new one...
    BigWater SE
    Oct 2005
    4
    My present psu reads as 300W with +12V@19A (350w is the reccomended psu for 600gt )
    so what do you guys suggest ?
    Use a new powersupply or RMA the card ????????
    Any thoughts?
    Aug 2003
    Madison, WI
    15,225
    Well, I would RMA it...even if your power supply is under powered...unless...could you try that 6600 GT in a different pc?
  1. GeForce 6600 power problem
    By Beastie2B in forum Graphics Cards and Displays
    Last Post: October 16th, 2005, 12:51 PM
  2. VISIONEER 6600 PROBLEM
    By BAPS in forum General Tech Discussion
    Last Post: September 29th, 2005, 07:21 PM
  3. 6600 GT installation gone wrong
    By Maloc in forum Technical Support
    Last Post: February 28th, 2005, 03:54 PM
  4. IE 6 Installation Problem
    By Charysh in forum Applications and Operating Systems
    Last Post: September 10th, 2003, 09:08 PM
  5. Installation problem XP
    By bnos in forum Applications and Operating Systems
    Last Post: May 10th, 2003, 02:38 AM
