Acer 17" DVI LCD Monitor w/ 6600GT causing problem!
Currently Active Users: 1600
Discussions: 200,505, Posts: 2,374,392, Members: 245,828
Old January 11th, 2006, 08:26 PM   Digg it!   #1 (permalink)
NightRise420's Avatar
Send a message via AIM to NightRise420
Well.... i just purchased a Acer 1715 monitor. It's hooked up with my AGP 6600GT DVI. Problem is, my monitor keeps turning on and off randomly. Also i don't see anything until it goes to log in screen. So i can't even go to bios. Is this normal for dvi interface? I'm used to vga...
Live Fast, Die Young, Dont Forget, Dont Regret
NightRise420 is offline   Reply With Quote
Old January 12th, 2006, 05:07 AM     #2 (permalink)
Banned
Three likely causes: 1) Monitor could have a defect. 2) The AGP/PCI isn't set for agp in bios.
3) The video card is slightly lifted in the slot where you have an intermittent contact. If the
problem persists after Windows has reached the desktop there are other concerns.
PC TECH250 is offline   Reply With Quote
Old January 12th, 2006, 05:30 AM     #3 (permalink)
Human voltmeter
DanU's Avatar
Do you have the DVI output defined as the primary monitor in your display properties?
Old January 12th, 2006, 05:54 AM     #4 (permalink)
Banned
A persistent problem could indicate a standby mode fault with the monitor since this is the
problem seen before Windows is fully loaded. If the problem was seen after the Windows
desktop was reached then a default display setting would be likely.
Old January 12th, 2006, 07:25 PM     #5 (permalink)
Yea i think so...
Old January 12th, 2006, 07:26 PM     #6 (permalink)
U mean that monitor not showing before windows loading is a common problem? If so, mine still goes on and off randomly while playing games or surfing the web. It happens randomly.
And i doubt its the video card being lifted b/c it works completely fine VGA but not with DVI.
Old January 12th, 2006, 07:56 PM     #7 (permalink)
Human voltmeter
DanU's Avatar
Hmm... maybe it's a bad DVI cable? Any chance you can swap cables temporarily with a friend/coworker?
Old January 12th, 2006, 08:06 PM     #8 (permalink)
Well i know its not a bad DVI cable because i used a DVI/VGA converter with that DVI cable to use it on analog mode and it worked fine. So it's not the cable b/c even the analog output wouldve been but it wasnt.
Old January 12th, 2006, 08:23 PM     #9 (permalink)
Banned
No, the problem with a monitor going into sleep mode before Windows is loaded
suggests a defect with the monitor itself. You should readily see the post screen on
any system without issues. The video card would also be suspect. The best way to
determine if the monitor is at fault is to run a different one on the system to see if
the same problems are experienced. If the problems remain, a bad video card or
another hardware is the cause. That would mean something else is failing.
Old January 12th, 2006, 08:36 PM     #10 (permalink)
problem is, i dont have any other computer with DVI port on the video card to test it out. I think it is a defect b/c monitor constantly says "no signal" randomly and comes back on when i use DVI even though its all fully connected.
LCD Monitor (DVI-D) rex028 Technical Support 4 September 14th, 2004 03:40 PM
LCD monitor and DVI cable sykocus Graphics Cards and Displays 5 October 19th, 2003 01:12 PM
15" or 17" LCD with DVI Cody Graphics Cards and Displays 9 September 6th, 2002 01:25 AM
17" LCD Monitor w/DVI, $482.89 shipped AR ABoyCalled3 ResellerRatings Homepage Deals 0 September 5th, 2002 02:33 AM
24.1" LCD 1920x1200 DVI-D digital video! $4500 Fisheagle ResellerRatings Homepage Deals 1 March 15th, 2002 11:40 AM
Is It Just Me? (1635)
Review My Build (5)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Mic won't work. (2)
