is this a good card. he are sum details:
XFX GeForce 7800GT Extreme LED Edition 256MB GDDR3 VIVO TV-Out/Dual DVI (PCI-Express) - Retail (PVT70G-UDF7) (GX-053-XF)
The NVIDIA Geforce 7800 GPUs supercharge gaming - delivering unparalleled performance and advanced visual effects for next generation games. Featuring a revolutionary superscalar architecture and backed by the NVIDIA Forceware software the Geforce 7800 GPUs deliver ultra-realistic effects, unmatched features, and rock solid stability so you can play your game the way it's meant to be played.
- Core clock 450MHz+
- 20 Pixel Pipelines
- 1050MHz+ GDDR3 Ultra Fast Memory
- 256-Bit Memory interface
- 7 Vertex Shaders
- Memory Bandwidth - 33.6GB/sec
- Fill Rate - 8.00 billion pixels/sec
- Next-generation superscalar GPU architecture
- NVIDIA® CineFX™ 4.0 engine
- 64-bit floating point texture filtering and blending
- NVIDIA® SLI™ Ready (NVIDIA SLI-certified versions of GeForce 7800 GTX only)
- NVIDIA® Intellisample™ 4.0 technology
- NVIDIA® PureVideo™ technology
- NVIDIA® ForceWare™ Unified Driver Architecture
- NVIDIA® nView® multi-display technology
- Microsoft® DirectX® 9.0 Shader Model 3.0 support
- OpenGL® 2.0 support
- 2 Years Manufacturer Warranty - Call XFX UK on 09068354400 for technical support and RMA services.
this cost £246
