February 27th, 2006, 02:26 PM #1Junior Member
- Feb 2006
- 7
my 6800gs sais there is not enough power
please, take a look at the screenshot i made.
http://img118.imageshack.us/my.php?i...ojmajke4ws.jpg
this happened to me for 3 times now. then after a restart it`s all back to normal. actually it does not even degrade performance how it sais (i checked in rivatuner). what could this be?
February 27th, 2006, 02:45 PM #2
make sure you have the extra power connector plugged in
if it is, then it looks like you need a new PSUHey who turned sigs on?
February 27th, 2006, 02:51 PM #3Junior Member
- Feb 2006
- 7
i have them both plugged in and my PSU is aa brand new one - chieftec delta350w. more then plenty to power up my amd64 3200, giga ram, msi neokf8 mbo and terratec ews88mt pci audiocard.
February 27th, 2006, 02:52 PM #4Senior Member
- Oct 2004
- Location
- Birmingham UK
- 522
dont be so sure on the 350W meetin the demands of that system
Opteron 146 @ 2.6Ghz
Freezer64
1024mb DDR500 RAM 3-4-4-8
Leadtek 7800GT 256Mb @ 450/1100 (515/1220 MSF)
DFI NF4 SLI-D 623-3
February 27th, 2006, 03:14 PM #5Junior Member
- Feb 2006
- 7
that kind of system takes max 200w, but more probably about 130
February 27th, 2006, 03:24 PM #6Chieftec makes crappy power supplys...very cheap....
Originally Posted by mirkov
I would get this one:
http://www.newegg.com/Product/Produc...82E16817104953
That has more than enough power for your system"The problem with quotations on the internet is that the sources are hard to verify" - Abraham Lincoln
February 27th, 2006, 03:39 PM #7Again the system probably requires more than you think. I have a Sempron 3100, 1 Gig of RAM, 2 drives, a 6800GS and an nForce3 motherboard and my 400w PSU started to crap out with the few case fans I had attached. Once I started unpluggin peripherals things went back to normal but I got a much nicer 430w PSU and system is fantastic now with all my stuff running.
YAH! I knew you'd be jealous
February 27th, 2006, 03:58 PM #8Junior Member
- Feb 2006
- 7
February 27th, 2006, 05:39 PM #9
Yeah, i'd get a new PSU if i were you. Return your current PSU if you can as its new, and buy a better one.
February 27th, 2006, 06:14 PM #10You can not simply figure out what amount of power you need by wattage...there is more to it than that...
February 28th, 2006, 11:35 AM #11
Yeah, thats definatly true on EX's part. it all depends on the rails you have etc etc. Basically, if your PSU is heavy its pretty good quality(believe it or not) if its light then its lower quality. Of course this will vary depending on the PSU's rating and what form factor it is, but it basically holds true.
Hard to imagine isn't it?
But then you can't figure which PSU to buy by feeling its weight lol.
February 28th, 2006, 12:25 PM #12Junior Member
- Feb 2006
- 7
ok, i am going for a new power supply.
are these good?
http://www.links.hr/index.php?option...kl=052.700.055
http://www.links.hr/index.php?option...kl=052.746.002
February 28th, 2006, 01:05 PM #13
japan power supplys? i doubt we could help you there.
February 28th, 2006, 01:15 PM #14
Both Tagan and Seasonic make very good power supplies. Either should serve you well. If you are looking for quiet, the Seasonic is the better choice.
February 28th, 2006, 01:35 PM #15
Mirko, these guys are quick to throw some money at a problem to solve it, I would first try out the card at a different pc, and see if the issue still comes up. Then I would triple check the connections.
Cheiftec makes decent power supplies, and I know for a fact you can run a similar configuration on a 350w declared chieftec psu.Buy the ticket, take the ride.- Hunter S. Thompson
February 28th, 2006, 02:11 PM #16
That seasonic is great...
Not the ones that I have used...the last one I replaced for someone was sooo cheap...it wouldn't even let you restart the computer...it would just hang on the boot...
February 28th, 2006, 02:25 PM #17
elmers- Thats because the problem is pretty simple. The card isn't at fault, but the PSU is...it says so in the screen shot
I'd go with the PSU's listed in the thread linked by Ex, this one: http://www.newegg.com/Product/Produc...82E16817104953
Cheap but powerful from a respected company.
February 28th, 2006, 02:32 PM #18
Well I've had a low end chieftec psu work for 2 years in a barton box that was always on. It worked perfect. Then I did something that I shouldn't have done, and burned the box. Still the psu was ok, even tho the mobo and proc were fried. It may be that I just got lucky?
Bucko: Once I start beliveing a computer you can put me out of my misery.
BTW Guys, I haven't seen newegg shipping to Croatia....Buy the ticket, take the ride.- Hunter S. Thompson
February 28th, 2006, 05:57 PM #19
Lol, well i do depending on what it says. But in this case, i don't see why it would lie about slowing itself down. Unless Nvidia stand to make money on PSU's people buy...ohhh
BTW- a barton system take much power? I wouldn't expect it does because with that type of CPU your not going to be using a power hungry GPU are you? Or a load of HDD's and DVD/CD drives probably. You might, but back in the barton day you needed less space...for me anyway, seeing as i like gaming and games are bigger and bigger lol.
If he's in croatia, then he can still find that PSU out there probably, or maybe give us a website from which he or she is looking to buy from so we can choose a good PSU in their price range.
February 28th, 2006, 06:35 PM #20
ok so you can shop for mirko with this link (the one he provided) link and you can check the prices by googling "xx kuna in dollars" where xx is the price on the site. I'm guessing he's looking to spend around 600kn.
<off topic> Barton ~ 70w + 2hd,1.5gb ram, 2cd, sb, tvtuner, 9600xt... its not that it drains a lot of power its that it was on 24/7 for p2peering, and then gaming once in the evening. Thats a lot of strain on the psu, don't you think?
Just a thought, it would be great if the psu was the issue here, but what if he spent the money and still had the same problem?Buy the ticket, take the ride.- Hunter S. Thompson
6800GS Vs X850XT
By NitramX9X in forum Graphics Cards and DisplaysReplies: 10Last Post: November 4th, 2006, 07:54 PM -
6800GS Video Problems
By KJ0055 in forum Graphics Cards and DisplaysReplies: 17Last Post: February 11th, 2006, 06:10 PM -
6800GS or X800XL?
By Adamdc in forum Graphics Cards and DisplaysReplies: 25Last Post: January 30th, 2006, 12:20 PM -
6800GS quick question
By MrLuigi in forum Graphics Cards and DisplaysReplies: 11Last Post: December 1st, 2005, 09:11 AM -
6800gs Vs. x800GTO
By him61 in forum Graphics Cards and DisplaysReplies: 9Last Post: November 25th, 2005, 09:27 PM
Oh, you can sit, just don't touch. I'll wince and cry like a baby.
