March 18th, 2006, 05:05 PM
#11 (permalink)
March 18th, 2006, 05:19 PM
#12 (permalink)
| | (AKA) Nakamura
that's ok... has 2 12 volt rails... which is good, but low amps on the 12 volt rails... hmmmm ... check this page out... this might help.... http://www.techimo.com/forum/t124252.html
it will give you some info about what pwr supplies and what type of amps you might look for...
P4 2.8ghz / MSI 865PE Neo2-PS / GeCube Radeon X1950XT 256mb agp / 2gb DDR400 / 2 X 80gb Samsung HD |
March 18th, 2006, 05:20 PM
#13 (permalink)
| | SoMuchAnime-SoLittleTime
| Quote: |
Originally Posted by KamikazeChipmunk | No way...Aspire is crap...just spend $10 more and get something good.
The mark of the immature man is that he wants to die nobly for a cause, while the mark of a mature man is that he wants to live humbly for one.
March 18th, 2006, 05:27 PM
#14 (permalink)
I agree, you want a good Power Supply to last you, not a cheap thing, because then all your specs could fry.
it will make all the difference... and you know that.
March 19th, 2006, 03:27 PM
#15 (permalink)
March 19th, 2006, 03:41 PM
#16 (permalink)
#17 (permalink)
What is the brand and model number of your current power supply? Look on the label on the side of the power supply.
There are several different styles of power supplies and if you don't buy the correct one it won't fit in your case. I would guess you have a standard ATX but I would check prior to buying a new one.
Typically there are ATX, micro ATX, and SFX.
Benjamin Franklin
March 19th, 2006, 03:45 PM
#18 (permalink)
| | ATI 4850 FTW!
That is a great deal for that Antec. I'd get that one.
That is, assuming it will fit. |
March 19th, 2006, 04:20 PM
#19 (permalink)
I'd get the one EX recommended since he always tells people to get it and they all come out satisfied
And its cheap for the performace people say it gives. |
March 19th, 2006, 08:30 PM
#20 (permalink)
I got the Antec 500w but it didn't help the problem. |
