Join TechIMO for Free!
Thread Tools
Currently Active Users: 2594
Discussions: 186,672, Posts: 2,227,747, Members: 230,317
Old March 18th, 2006, 04:36 AM   Digg it!   #1 (permalink)
Graphics card problem
I have a 6800 and when I turn my computer on, their are blue lines and specks on the Windows start up page. Then my computer doesn't load, restarts, or becomes vertical black and white lines. I have the newest driver. Anyone know whats wrong?
KamikazeChipmunk is offline   Reply With Quote
FREE instant scan
Old March 18th, 2006, 04:58 AM     #2 (permalink)
(AKA) Nakamura
sweeper2's Avatar
first off... how old is the pc...
is it home built or from the factory...
was it working previously or have you tried to overclock it and now it does this...?
is it a new card ?? (replacement)
P4 2.8ghz / MSI 865PE Neo2-PS / GeCube Radeon X1950XT 256mb agp / 2gb DDR400 / 2 X 80gb Samsung HD
Old March 18th, 2006, 05:09 AM     #3 (permalink)
I got the PC about a month ago, and the card about 3 weeks ago. Factory built HP. It was working for the first week or two even after i overclocked it. My onboard chipset works fine though
Old March 18th, 2006, 05:15 AM     #4 (permalink)
(AKA) Nakamura
sweeper2's Avatar
sounds like a PSU problem... you say your onboard video works... but the card doesn't..... is your onboard drivers the same as the new card drivers... if not, you need to uninstall your old drivers and reinstall your new ones....
but it really sounds like a pwr issue or a bad card... (most likely a power issue)
how many watts is your PSU ....
Old March 18th, 2006, 01:56 PM     #5 (permalink)
300w
Old March 18th, 2006, 02:09 PM     #6 (permalink)
Reaper
him61's Avatar
Send a message via AIM to him61 Send a message via MSN to him61 Send a message via Yahoo to him61
That would most likely be a power issue then. Since its factory-made they definitelly put a crap PSU in there. If you would like to buy one I'd reccomend this one:
http://www.newegg.com/Product/Produc...82E16817104953
At long last, I got my country back!
him61 is offline   Reply With Quote
Old March 18th, 2006, 02:23 PM     #7 (permalink)
Can you recommend a cheaper PSU?
Old March 18th, 2006, 03:55 PM     #8 (permalink)
(AKA) Nakamura
sweeper2's Avatar
well, first off, with your pc being an HP (factory) ... what is the model number of your system... like HP 5100 .. something like that...
it might be that you would need a certain type to fit the (PC tower) ... unless a standard PSU can fit...
also, that's pretty cheap for a PSU that was recommended above... you don't want to go real cheap.. you would end up in the same situation you are in now....
Old March 18th, 2006, 04:07 PM     #9 (permalink)
It's a pavilion a1310n
Old March 18th, 2006, 04:42 PM     #10 (permalink)
(AKA) Nakamura
sweeper2's Avatar
so you have a PCI-E video card..
i would contact HP or take out the power supply (and take it to a PC store and see if one matches) and see if you can find a better PSU .. with more Watts... look at finding one with a good 12 volt rail , I would go with about 400 at the minimum .. but look at maybe 450 to 500 ...
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Graphics card problem mark2512 Graphics Cards and Displays 11 March 14th, 2006 06:52 PM
Graphics Card problem #43 fan Graphics Cards and Displays 9 October 5th, 2005 08:31 PM
NOBODY knows about this graphics card problem! techbird Graphics Cards and Displays 31 May 30th, 2004 12:38 AM
Graphics Card TV Out problem agtelford Graphics Cards and Displays 1 November 12th, 2003 04:18 PM
Graphics Card Problem rabidturtle Technical Support 4 October 27th, 2002 03:01 AM
Video card compatability. (7)
Is It Just Me? (634)
Is this a good laptop for gamming? (6)
Bought an AGP "HIS Radeon HD 3.. (18)
Outlook add-in won't remove. (9)
Presario Help (6)
Misery Loves Company... (1873)
Putting together my wish list (17)
Folderchat: The Holiday thread (156)
New info on the Phenom II X4 (32)
[Help] Computer Freeze (3)
Best Boot Drive Imaging Softwar.. (2)
File associations (2)
is there a way to Grep for a sp.. (6)
Automatic Updates Turns off Aut.. (10)
Is this a good laptop for gammi.. (6)
Giga Pocket Junk (1)
Seald copy of windows 95 for sa.. (1)
