still got slight vid card problems !!!!
Currently Active Users: 1225
Discussions: 200,929, Posts: 2,379,148, Members: 246,296
Old July 7th, 2006, 11:13 AM   Digg it!   #1 (permalink)
i had a problem with my video car a couple of days ago , i rolled back the driver and eveything seemed fine , yesterday i played f.e.a.r for about 2hours
the game played great ..everything was good ....but
when i quit the game and went back to my desktop it seemed as if there were windows half way opened and the screen would blink every second ....i turned the pc off then back on and everything is fine.
but it did it again i played for lil bit more and it did the same thing.
anyone have any tips? ...im getting really frustrated
should i uninstall everything then install as if i just put the card in ?
problem when i first installed the card i forgot to uninstall the previous card drivers.
then i installed the latest 91.31? drivers then went back to the older drivers ...so im not sure if that might have anything to do with it ?
dell xps 400
pd930/2gb ram/ e-vga 7900gt (stock)
3dmark03=????/3dmark06=????/Aquamark3=82,907
valos1479 is offline   Reply With Quote
Old July 7th, 2006, 12:03 PM     #2 (permalink)
ANY RECOMMENDATIONS?
Old July 7th, 2006, 12:08 PM     #3 (permalink)
Send a message via AIM to CharmedLover84
OH MY ******* GOD! This is the EXACT same problem I had.
91.31 seems to make performance and the problem worse.
Mine only happens when I'm in SLI though, not when I'm using only one card... Maybe our cards (in my case my second card) are both defective? LOL
CharmedLover84 is offline   Reply With Quote
Old July 7th, 2006, 12:10 PM     #4 (permalink)
http://www.techimo.com/forum/t170691.html ~~~ theres my thread on it, it's with an XFX card too so maybe these super-overclocked cards we both have don't always work right (like I said one of mine works fine by itself, the other is questionable in SLI.)
Old July 7th, 2006, 12:12 PM     #5 (permalink)
分かりますか。
carl33p's Avatar
Send a message via AIM to carl33p
Stick with the drivers that work best for you.
Is your card still overclocked? May have something to do with it.
carl33p is offline   Reply With Quote
Old July 7th, 2006, 12:14 PM     #6 (permalink)
no it hasnt been overclocked since i benchmarked it .....plus when i did the 91.31 drivers it set itself to stock settings and wouldnt let me change the freqeuncies....
so i rolled back the drivers ....and now im getting the problem i wrote on my first post
Old July 7th, 2006, 12:23 PM     #7 (permalink)
I think it may be a combination of hardware and driver problems.
BUT I tried changing drivers, uninstalling, reinstalling... hell, I even reinstalled WINDOWS and it didn't fix the problem, so I think it's more hardware than software.
Old July 7th, 2006, 01:08 PM     #8 (permalink)
how can i remove everything like all drivers pretty much anything that pertains to the geforce and start from scratch ?
Old July 7th, 2006, 04:22 PM     #9 (permalink)
won't work, but you can try it. Either a completely new install of Windows after formatting your drive, or a complete uninstall of all NVidia drivers. It won't work though dude, I tried it. Twice.
Old July 7th, 2006, 04:31 PM     #10 (permalink)
XxCowOfChaosxX's Avatar
Send a message via AIM to XxCowOfChaosxX
Maybe it has something to do with what's in this article.
XxCowOfChaosxX is offline   Reply With Quote
Problems with mouse/vid card? StonedRaider Technical Support 7 October 23rd, 2005 08:09 PM
F\S Vid Card, NIC, Sound Card, and MORE! robexe Traders Forum: Buy, Sell, Trade 15 March 7th, 2004 05:26 PM
Problems With Vid Card.. Isolate Technical Support 3 December 26th, 2002 02:03 PM
new vid card! firemachine69 Graphics Cards and Displays 20 December 11th, 2002 08:27 AM
Having problems with a vid card rebate. Asdfga3 General Discussion and Buyer Guidance 2 October 5th, 2002 12:22 PM
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
