Page 2 of 10 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 21 to 40 of 187
  1. #21
    Dec 2006
    23
    Quote Originally Posted by phanz View Post
    Have you tried disabling "DirectMedia Acelleration" or "Windows Media Acceleration" or a similar option in the nvidia drivers?
    No I'll try that now. Thanks.
    :: edit ::
    Just to let you know, my current drivers are:
    93.71_forceware_winxp2k_english_whql.exe
  2. #22
    Dec 2006
    23
    Phanz, I can't find these options.
    Can you give me a pointer please?
  3. #23
    Jul 2006
    8
    I assumed Nvidia had this option in its driver property settings, I know ATI does. Do you know if its only .WMV videos youre having trouble with or .MPG and .AVI as well?
  4. #24
    Dec 2006
    23
    Yes it happens with all videos...
    Something wierd I've just noticed is when I run the video I get 100% CPU usage and slowdown. As soon as I hit [CTRL]+[ALT]+[DEL] and hit task manager, the video runs normally behind task manager. It seems once the CPU has been interupted, it frees itself and plays normally.
  5. #25
    Jul 2006
    8
    Have you tried reinstalling your motherboard drivers since you have been changing out your video drivers? If you are a running a Asus board, give the Nforce all in one drivers a try. Make sure you restart after the installation.
    http://support.asus.com/
    Or direct link for XP
    http://dlsvr01.asus.com/pub/ASUS/mis...f2v116_wxp.zip
  6. #26
    Dec 2006
    23
    Thanks Phanz,
    I'm redownloading all the latest drivers for my mobo.
    The only thing I cant download is the manual, which would have been nice.
    The download rates are very slow, so it'll be a while before I get back to you.
  7. #27
    Jul 2006
    8
    Also, were you running an ATI card before this card? You should run Driver Cleaner Pro (freeware app i believe) to delete any ATI driver entries.
    http://www.softpedia.com/get/Tweak/U...essional.shtml
  8. #28
    Dec 2006
    23
    Ah, indeed I was.
    I was running an ATI Radeon 9200 SE.
  9. #29
    Jul 2006
    8
    I think Driver Cleaner Pro will be your best bet. If clearing any ATI entries and a reboot doesnt fix your problem, try the Nforce driver install.
  10. #30
    Dec 2006
    23
    Ok i did an ATI driver clean, and it found about 10-15 files.
    The other drivers are going to take about an hour to finish, so I haven't restarted yet.
    I've gotta go out now, but I'll pick up where I left off, and post back my results.
  11. #31
    Jul 2006
    8
    Good luck man. Keep us informed!
  12. #32
    Dec 2006
    Hey all, first post! I have the exact same problem as the original poster and same video card. Also previously had an ATI card (9800 Pro). I've had this problem for months now and just work around it, the way i do that is going into control panel and disabling the Nvidia card and re-starting. Video plays fine when the card is disabled. It's getting annoying though and my search brought me here. I've used the Cat-uninstaller thinking i most likely had some conflicting video card drivers fighting for who gets the right to play my videos!
    Soo just wondering if the OP ever got this figured out???? I'm going to read back up through the post and see if any of those tips help me out.
  13. #33
    Xyn
    Xyn is offline
    Dec 2006
    6
    Same Problem
    I just got the same card upgraded from the same raedon. Same beautiful problem as you seem to have. My games, desktop, and general programs run flawlessly, but when i start up my media...All hell breaks loose to the point where i have to ctrl+alt+delete(wait 20 mins while it pops up) end the process of the media player i am using(wait another 20 mins while it is clicking on the right process) and end it(another long wait). I tried the codec that was suggested earlier in the fourm and am tring the asus chipset now(i also have a asus motherboard). Just adding in my problem as well ;p
  14. #34
    Xyn
    Xyn is offline
    Dec 2006
    6
    Phanz, i love you dude. Lol. Just installed the chipset and it works! Wootness...thanks a bunch for the posts and starting it, paul. The chipset should work for you too
  15. #35
    Dec 2006
    26
    dfi infinity board
    using a DFI infinity board with the same issue.
    going to try to find the new drivers and see what happens.
    thank you for working on this issue, shall post my result as soon as i have one.
  16. #36
    Dec 2006
    26
    having trouble finding updated drivers for my mobo from DFI. the main issue is they no longer sell (or seemingly support) this particular Infinity 865PE board. If anyone else has any ideas, please let me know.
  17. #37
    Dec 2006
    7
    Guys the exact thing happened to me. Just installed the BFG GeForce 7600 GS and it has wrecked all of my media applications!
    Was using a GeForce FX 5200 not an ATI previously...
    Wish I knew the manufac. of my mobo
  18. #38
    Dec 2006
    7
    Quote Originally Posted by Skippy07 View Post
    I took the initiative popped open my comp found the mobo maunfac. googled the serial # updated the driver and holy sh*t it worked!
    Happy New Year!
  19. #39
    Dec 2006
    26
    i'll give it a shot, i'm sure it's got something to do with my mobo, i'm just having severe issues finding drivers that are newer than what i have for my DFI Infinity 865PE.
  20. #40
    Dec 2006
    7
    Damn, I got my media applications running, now my games load up with blank screens!
    Thinking I should take out the vid card and reinstall, now that I have updated my mobo drivers?
  1. HELP! Problem upgrading ram from 512mb ddr2 to 1gb ddr2
    By dabooj in forum Processors, Memory, and Overclocking
    Last Post: January 21st, 2008, 08:57 PM
  2. geforce 7600 gs oc 512mb power conflict need help
    By Fazzazerin in forum Graphics Cards and Displays
    Last Post: February 12th, 2007, 03:26 PM
  3. Graphics Problems With GeForce 7600 GS OC
    By NoJabbaNoBogRoll in forum Graphics Cards and Displays
    Last Post: December 15th, 2006, 07:13 AM
  4. BFG GeForce 7800 GTX OC vs BFG GeForce 7900 GT
    By JeanSamedi in forum Graphics Cards and Displays
    Last Post: April 26th, 2006, 06:41 PM
  5. BFG Geforce FX 5200 problems
    By niall g in forum Graphics Cards and Displays
    Last Post: December 14th, 2004, 12:13 AM
