DVI output to DVI LCD monitor... ??
Currently Active Users: 1701
Discussions: 200,924, Posts: 2,379,124, Members: 246,290
Old December 31st, 2006, 05:20 AM     #11 (permalink)
Coolzer's Avatar
Originally Posted by sweeper2 View Post
wow.. don't hold back your thoughts any.... hey... not all of us can afford the "finer" things in life....
Well it's best not to beat around the bush, right? You wanted an answer to your problem; Wir's is one possible scenario. I don't think he was picking on you or anything, just offering his personal opinion.
Coolzer is offline   Reply With Quote
Old December 31st, 2006, 06:11 AM     #12 (permalink)
(AKA) Nakamura
sweeper2's Avatar
meh .... answer to my problem was...
Peter M:
Dot "twinkle" is a sign of poor DVI signal ... something that older NVidia cards are quite notorious for.
But nevermind, LCDs do not "refresh" and hence do not flicker, regardless of the image rate you feed them. 60 Hz is OK, and is actually the recommended setting.
NOT --- your monitor is cheap...
P4 3.0ghz , P4M900-M4 , 450 psu , Sapphire HD 3850 512mb with an Accelero S1 cooler , 2gig pc5300 ddr2, 80gig Deskstar , 16x dvd-rw
Old December 31st, 2006, 07:27 AM     #13 (permalink)
just passin thru
Sweeper's Avatar
P4 3.2 'E', 4GB DDR400, XFX Geforce 6600GT 256MB AGP, MSI 865PE Neo2-P, WD S-ATA II 500GB HDD, Win. Vista
Sweeper is offline   Reply With Quote
Old December 31st, 2006, 08:09 AM     #14 (permalink)
Coolzer's Avatar
ok, sorry you have that view, and it seems that i interperate his post far differently than you. I don't believe that he made a direct attack, just Maybe you both should be a little more "thick skinned" and not take such posts to heart.
Wir said he believed his LCD was cheap, you call that "bashing", or really insulting, hmm maybe you should just grow up.
Old December 31st, 2006, 10:46 AM     #15 (permalink)
just passin thru
Sweeper's Avatar
Old December 31st, 2006, 11:00 AM     #16 (permalink)
JLK03F150's Avatar
Send a message via ICQ to JLK03F150
sweeper2, take a look at my Display Properties. Under Advanced Timing, Vertical Lines I had to lower the Refresh Rate to 48Hz. Since you are running 1440x900, I'd start with 58Hz & lower it a few Hz at a time until the "twinkle" clears up. Make sure you have vsync set to Off or Application Controlled or you'll cap your games max FPS.
JLK03F150 is online now   Reply With Quote
Old December 31st, 2006, 11:49 AM     #17 (permalink)
Capping the games max FPS is a non-issue, simply because any extra frames per second that get /rendered/ will nonetheless not get /displayed/ ever. Having the display refresh rate set to N Hz (N=60, 75, 85, 58, whatever) means you're sending N frames per second to the display unit - and no matter whether the graphics card renders 60, 61 or 261, you'll always get to see 60.
Disabling Vsync may be helpful when your graphics card can NOT keep up - instead of dropping from steady 60 fps to steady 30, you'll get the frames when they're ready - with better-than-30 framerate, but at an unsteady rate.
Peter M is offline   Reply With Quote
Old December 31st, 2006, 02:58 PM     #18 (permalink)
ph34r t3h g04t
Whir's Avatar
Yes, I called his LCD cheap. Get over it guys. I paid a whopping $170 for mine. You want to get offended because I think Envision is a throwaway brand, go ahead. I sell the stuff for the a living, I sort of know what I'm dealing with.
Such as it is, Peter M (as usual) had an answer for the situation and I was mistaken about the twinkle problem.
There was certainly no reason to start an argument over it, Coolzer and Sweeper, I'm fully capable of explaining myself to offended parties. If Sweeper2 really had a beef with me, I'm sure he would have sent me a PM and discussed it like an adult.
Old December 31st, 2006, 03:52 PM     #19 (permalink)
(AKA) Nakamura
sweeper2's Avatar
thanks "Sweeper" for agreeing with me... (of course he will agree... he is my brother.. )
Next up ... Whir... i really didn't think Envision was "cheap" ... I really don't have a beef with anybody... i just went over some LCD's and to be able to afford one... this one was the best choice... with good reviews and specs ...
the best way I guess to avoid anything like this... is just stick to the topic... without throwing in any "remarks" about someones hardware...
but all in all.. let's just toss this thread out.... Whir.. your the MOD .. lock it up.. Please...
Old January 1st, 2007, 03:12 AM     #20 (permalink)
just passin thru
Sweeper's Avatar
Help can't use DVI connection to LCD monitor!! sandydoull Graphics Cards and Displays 4 July 12th, 2006 09:25 PM
Acer 17" DVI LCD Monitor w/ 6600GT causing problem! NightRise420 Graphics Cards and Displays 27 January 13th, 2006 06:07 AM
LCD Monitor (DVI-D) rex028 Technical Support 4 September 14th, 2004 03:40 PM
LCD monitor and DVI cable sykocus Graphics Cards and Displays 5 October 19th, 2003 01:12 PM
17" LCD Monitor w/DVI, $482.89 shipped AR ABoyCalled3 ResellerRatings Homepage Deals 0 September 5th, 2002 02:33 AM
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
