PSU power supply problem
Currently Active Users: 1899
Discussions: 204,517, Posts: 2,419,565, Members: 249,933
Old January 23rd, 2007, 11:00 PM   Digg it!   #1 (permalink)
I recently just bought a geforce PCI-e video card from tigerdirect and it's shipping right now. The system requirements is 350W power supply. But I JUST FOUND out my system only has a 305W PSU. What should i do? =/ please help. Do i have to get a new one? I read previous threads on this issue, but I was wondering if my issue can be exceptional. My PSU specs are 305W with 12Va being 18.0a and 12vb being 18.0a. I have a Dell 5010
concealed777 is offline   Reply With Quote
Old January 23rd, 2007, 11:04 PM     #2 (permalink)
Megalomaniacal
SoloCamo's Avatar
Send a message via AIM to SoloCamo
Welcome to TechIMO!
What video card did you order?
What are the rest of your system specs?
What is the make/model of your psu?
Most likely you will need to upgrade however
SoloCamo is offline   Reply With Quote
Old January 23rd, 2007, 11:10 PM     #3 (permalink)
I have a Dell Dimension 5010, 512 DDR2 ram. Intel Pentinum 4 3GHZ. The PSU is also Dell
Video card is 3d Fuzion Geforce 6200 LE 128 MB
Old January 23rd, 2007, 11:15 PM     #4 (permalink)
Training for Bankai
JPMiller's Avatar
Across the board, Dell's ship with the absolute minimum spec PSU they can get away with...
That way they can charge you for an upgrade down the road, or negate your warranty if you upgrade without them...
305 is too low for most current systems when adding ANY kind of upgrade...
While your card may not overload the system right away, the added drain WILL make it run hotter and harder...
Eventually you may pay the price with the demise of key components when/if it blows
As long as it is a standard ATX ( 3.5" x 5.5" x 6" roughly) then you can simply swap it out with a higher quality unit..
The lowest end FSP is only around $30 shipped and still leaves headroom for other upgrades...
http://www.newegg.com/Product/Produc...82E16817104951
1 x Main connector (20+4 pin)
1 x 12V (P4)
4 x peripheral
1 x SATA
If you need more connectors than that, then you may want to bump up to a higher end model...
Dont be fooled by the 300W rating...
those are TRUE ratings unlike most PSU's and the +12V rails are the ones that are important...
+12V1@16A
+12V2@16A
This config is more than most 450W generic PSU's
Old January 23rd, 2007, 11:17 PM     #5 (permalink)
What if the video card is the only upgrade i am adding?
Old January 23rd, 2007, 11:29 PM     #6 (permalink)
Training for Bankai
JPMiller's Avatar
Do so at your own risk...
I'm warning you for good reason...
You may be just fine...
Me, I would at LEAST check voltages with EverestHome before the upgrade, and again after, while under load...
run a graphics test and watch if they fluctuate or dip much....
Voltage values SHOULD show up under "Computer" "Sensor"
if its still greyed out after clicking on the sensor tab, wait a moment, if it still doesnt show, thank Dell for stripping out any form of motherboard monitoring...
Old January 23rd, 2007, 11:35 PM     #7 (permalink)
I have everesthome. under computer and sensor, i only have the temperature? the thing is, the video card i am getting is only 50 dollars, I am a very low budget gamer and i am only getting it for kind of low end games like wc3 and lineage 2.
the new card is just a 3D fuzion Geforce 6200 128 Mb. It runs at 350W. Can i underclock it to make it use less enrgy?
Old January 24th, 2007, 12:24 AM     #8 (permalink)
Dethrattle's Avatar
Send a message via AIM to Dethrattle
There is almost no reason to upgrade to the same card.
Maybe you should save up and get something a little better.
At least come up a generation and get a 7300GS for the same price.
X2-4400 2.4Ghz
8800GTS, yay
Antec 500 PSU
Dethrattle is offline   Reply With Quote
Old January 24th, 2007, 12:54 AM     #9 (permalink)
well my old one is just some intel chipset family one. my psu is only 305W output though.
Old January 24th, 2007, 02:34 PM     #10 (permalink)
Human voltmeter
DanU's Avatar
Well if it's just a low-end GF 6200, then your 305W PSU should be fine. These cards don't draw much power.
It will definitely be a step up from your intel integrated graphics, but like everyone else said, it's not a "gamers" video card by any means. For older games like WC3, you should be just fine.
power supply problem mysundown1305 Technical Support 4 December 27th, 2004 10:14 PM
Power supply problem? VillageIdiot906 Technical Support 19 July 4th, 2004 05:03 AM
Power supply problem? mmcmahon Technical Support 1 August 22nd, 2003 06:15 AM
Power/power supply problem jerrygarcia Technical Support 16 March 18th, 2003 08:49 AM
Power Supply Problem Etruscan Technical Support 4 September 8th, 2002 03:29 AM
Is It Just Me? (1623)
D.O.D. dismantles Terrorist forum. (6)
USB not recognised..... (16)
First time builder (6)
Recent Problem (15)
Need some suggestions on building a.. (32)
HTML (5)
[ F@H Chat] 03/07/10 New Month New.. (90)
Motherboard the culprit? (7)
Windows XP Pro Error log (9)
Can't Rename Files (11)
Suggestions? (6)
re laptop (1)
pc won't start (1)
HTML (5)
newegg=bad people (27)
Outlook keeping 2 copies of sent mess.. (1)
Audio skips when I play a cd or dvd o.. (2)
Microsoft removes hardware virtualiza.. (1)
Lexmark Printer Prestige pro805 (1)
Hypercam 2 plays sound too fast (1)
Need some suggestions on building a g.. (32)
[ F@H Chat] 03/07/10 New Month New T.. (90)
IE8 & WLM crash whenever I try to.. (1)
iPad, who's getting one? (60)
Writing lead-out (8)
SSH Tunnel Or OpenVPN? (1)
About to install a new heatsink and I.. (3)
169 ip address question (4)
Help! Cisco Switch port (interface) f.. (1)
burner not burning. (4)
Sim Societies won't launch (0)
Hard drive full = slower computer? Is.. (6)
