Results 1 to 19 of 19
    Jan 2007
    40
    6800GT runs in 2D, but not 3D mode. Please help!
    Hi, someone has a BFG 6800GT that works fine in 2D mode, but in 3D mode the card starts to have problems as well as in benchmarks. Could this be due to the card not having enough power? Or should I try to RMA the card as a busted card?
    Feb 2007
    Springfield
    13,484
    5
    How big of a power supply do you have?
    FAQ's ~ Team Stats
    My PC
    Jan 2007
    40
    Err, sorry, it isn't my card, not sure why I wrote mine, just helping someone troubleshoot for the card. I'm trying to find out on the PSU size and the amps on the 12v. But until then, I was just trying to see what this could be caused by.
    分かりますか。 carl33p's Avatar
    Feb 2006
    Gville, FL
    7,170
    9
    Could be due to temps, underpowered, or possibly drivers.
    First I'd suspect it being underpowered; if not, download Everest Home Edition and check out the temps.
    Try to get the manufactuer, watts, and 12V amps: all should be located on the side sticker of the power supply.
    I Haz Catputer JLK03F150's Avatar
    GA
    5,435
    You want about 18amps on the +12v rail to run that card.
    You can monitor the temp's from the 6800gt tab of the advanced display properties.
    Jan 2007
    40
    Ya I told him to make sure he has 18 or more amps on the 12v. I'm waiting for him to get back to me. I was suspecting that would most probably be the issue, since there is no problem until it goes into 3d mode in a game or benchmark. I guess I'll wait for his response and go from there. Thanks
    Onii-san Bizkitkid2001's Avatar
    Sep 2002
    San Antonio
    10,975
    What are the "problems" it has in 3D?
    Jan 2007
    40
    I was told it just completely messes up. I'm assuming either "rainbow" screen, black screen or just a reboot. I will try to find that out too.
    Sep 2002
    San Antonio
    10,975
    Quote Originally Posted by mrhelloo View Post
    Depending on what it does will depend on the fix.
    For instance, if nothing 3d will even start, I'd say it was a driver issue.
    If he is getting artifacts in 3D (discolored/large/stretched pixels) that I would say its either bad ram or an overheating issue.
    If the computer restarts after running something 3D then I would say an underpowered PSU.
    Let us know exactly what he experiences.
    Aug 2003
    Madison, WI
    15,225
    Biz, getting artifacts can be a sign of low power as well.
    Try getting a screenshot and see if the artifacts show on the screenshot as well.
    Jan 2007
    40
    Ok I got some more info from him. He is using an ASUS MB and an Antec 550w PSU which should be more then enough for this card. When he tried to benchmark the card or play BF2 or any game, he says he gets a lot of snow type artifacts and rectangle boxes around the screen.
    The part I find weird is I checked this card in 2 systems in my house to make sure it was working. Worked without any problems in Benchmarks as well as any game I tried with it. I'm trying to see if the RMA route is the way to go, or there is something simple that I'm missing.
    Feb 2006
    Gville, FL
    7,170
    9
    Possibly his drivers.
    Make sure he has the most recent nvidia drivers.(And they are the correct ones)
    Also, if there is a power connector on the card, make sure he has it plugged in!
    If the card works on other computers, just not his, the card is most likely fine.
    Sep 2002
    San Antonio
    10,975
    Download and install the latest motherboard and video card drivers.
    Make sure that the power connector is plugged in.
    Test the system ram with memtest86
    Check the temperature of the video card (Should be under advanced display settings)
    Jan 2007
    40
    Display and chipset drivers were updated. The card is plugged in through the molex, going to a 550w Antec PSU. His system works perfectly with his old video card, but once the 6800GT gets put in, it won't run in 3d mode without artifacting like crazy.
  15. #15
    Aug 2003
    Madison, WI
    15,225
    Is the 6800 GT new, used, or what?
  16. #16
    Sep 2002
    San Antonio
    10,975
    What is the temperature of the card when running a game? If it is not a heat issue, I am going to suspect that the motherboard is at fault.
    Can you get another video card from a different computer and run it on your friends motherboard to see if it has artifacts as well?
  17. #17
    Jan 2007
    40
    Used card but worked without any problems at all in two of my systems. He says his old 9800 works without any problems. I'm not sure about the temp.
  18. #18
    I got this #43 fan's Avatar
    Mar 2005
    Midwest
    5,560
    Did he uninstall the old drivers (the ATI ones)? That may well be the problem.
  19. #19
    Jan 2007
    40
    Yup, he said he uninstalled and reinstalled new drivers. Installed new chipset drivers. Checked to make sure the card was seated with no problems and plugged in.
  1. PCI Mode, how to change to AGP MODE
    By soulja in forum Graphics Cards and Displays
    Last Post: June 5th, 2007, 07:09 PM
  2. Replies: 2
    Last Post: April 14th, 2005, 11:27 AM
  3. is BFG 6800GT OC really worth almost $100 for than 6800GT?
    By MeskoJ in forum Graphics Cards and Displays
    Last Post: March 24th, 2005, 11:51 AM
  4. CD/DVD drives recognized in safe mode, but not regular mode
    By Headstrong in forum General Tech Discussion
    Last Post: December 21st, 2003, 06:04 PM
  5. XP-runs in safe mode, but won't boot up normally???????????????
    By wavewuver in forum Technical Support
    Last Post: August 20th, 2003, 09:25 PM
