NEED YOUR HELP INSTALLING MY GRAPHICS CARD
Currently Active Users: 2362
Discussions: 200,942, Posts: 2,379,331, Members: 246,305
Old July 6th, 2007, 01:45 PM   Digg it!   #1 (permalink)
i found a radeon 7000 graphics card in my closet. Im trying to get it to work, i dont have the cd anymore for the drives but i do have the drivers downloaded from the ATI site. So anyway.. whats the process?? I unplugged everything and popped off the side and snapped the card into a slot.. I go to hook up the monitor and it dosnt wanna turn on. wats wrong
JINX1 is offline   Reply With Quote
Old July 6th, 2007, 01:47 PM     #2 (permalink)
Megalomaniacal
SoloCamo's Avatar
Send a message via AIM to SoloCamo
Hey and Welcome to TechIMO!
First of all, what are your complete system specs? That Radeon 7000 is quite the old card and it may very well not be compatible with your system.
What slot did you put it in?
SoloCamo is offline   Reply With Quote
Old July 6th, 2007, 01:52 PM     #3 (permalink)
Intel(R)
Celeron(R) CPU 2.80GHz
2.81 GHz 496 MB of RAM
and i snapped it into the only slot that it fit into correctly.
is that the right info??
Old July 6th, 2007, 02:04 PM     #4 (permalink)
Megalomaniacal
SoloCamo's Avatar
Actually the motherboard model would be preffered. You can get it by either physically opening up your case and looking, or downloading a program called EverestHomeEdition that will tell you all you need to know.
Old July 6th, 2007, 02:08 PM     #5 (permalink)
Motherboard ID 9/19/2005-P4M800CE-8237-6A7L6B09C-00
Motherboard Name: Unknown
thats what was under motherboard properties
Installing a graphics card (first timer) stevenpa Graphics Cards and Displays 6 April 23rd, 2007 12:10 PM
installing graphics card help please MzDonna Graphics Cards and Displays 12 April 14th, 2007 01:32 AM
Installing Graphics card thegreekusa Graphics Cards and Displays 2 March 31st, 2007 01:16 AM
Problems installing a second graphics card DJBERG Graphics Cards and Displays 10 August 28th, 2004 04:47 AM
Installing a PNY Tech. graphics card weemoney Technical Support 2 September 26th, 2003 01:20 AM
Making Health Care Worse (159)
The disrespect of Obama by Russian .. (14)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
