Join TechIMO for Free!
Thread Tools
Currently Active Users: 2453
Discussions: 186,672, Posts: 2,227,760, Members: 230,317
Old August 3rd, 2007, 04:36 PM     #11 (permalink)
Question
well i got a new powersupply and that didn't help. the driver issue did come to mind since i forgot to uninstall the old one but i dont think the driver would just not work (think about having a system that had windows on it yet - would the grpahics card not work then?). The motherboard isa Asus A8N - SLI - SE http://www.amazon.com/ASUS-A8N-SLI-S.../dp/B000CRR4HI.
Someone was talking about a 6pin connector instead of a molex - on my card its is a molex (4pin - same as the one you put into the hard drive and dvd rom) this is my card http://www.powercolor.com/eng/produc...?ProductID=516
i sent backthe card and the replacement is coming in a week but im gonna pop own to circuit city and get a cheap one to test. If it isnt the graphics card i can only think it would be the processor which i damaged when putting it in the new motherboard. Does anyone know if u can load the bios without a working processorr?
moody3d is offline   Reply With Quote
Old August 3rd, 2007, 04:55 PM     #12 (permalink)
TOAD6147's Avatar
Send a message via ICQ to TOAD6147
That's probably your problem. Also, make sure you don't have any anti-virus or spyware monitoring software running in the background.
""...they got the guns but we got the numbers..."
Jim Morrison
TOAD6147 is offline   Reply With Quote
Old August 3rd, 2007, 04:58 PM     #13 (permalink)
but the bios doesnt een come up on screen. i mean if someone with a new pc without windows installed on it yet wanted to use that graphics card, surely they would be able to
Old August 3rd, 2007, 06:02 PM     #14 (permalink)
TOAD6147's Avatar
POST beep codes? Take everything out but one stick of RAM and the video card and see if you can get to POST. Be sure the RAM and vid card are properly seated.
DUH!! I just saw this:
UH, no!! How did you "damage" it?
Old August 3rd, 2007, 07:08 PM     #15 (permalink)
well when i took my old processor out, i bent the pins, so i got a pen (metal) and pushed them back inline. if i connect one or more pins together, with it short-out the processor. if it does, then i think the processor is done - i got a new card from circuit city, and that didn't work. so it wasnt the graphics card i feel (however the new card was a pci not a pci-express) and the motherboard has power, so im pretty sure its just the processor. but shouldnt the bios load anyway?
Old August 3rd, 2007, 07:28 PM     #16 (permalink)
TOAD6147's Avatar
Old August 3rd, 2007, 09:11 PM     #17 (permalink)
nemowolf's Avatar
If you bent a pin on your processor, then tried to fix it, consider it toast. I highly doubt you used an antistatic wrist strap and then used a random metallic object (pen in your case) to straighten it. You need to start with a new processor as the above post mentions. Most likely you have caused a short or some kind in one of the two bends which is causing a problem. In addition, depending on the damage done to your processor, it might have further damaged your mobo.
Start with replacing those two and as above, good luck!
Old August 4th, 2007, 07:10 AM     #18 (permalink)
Yeah, on my card the socket where the extended power cable goes into is a six pin, similar to pci-e connections.from that six pin it runs to two 4-pins. Anyway, it seems like u damaged those other two pieces of hardware. but before u take any drastic measures in buying new ones, why not take ur pc to connection city so they can troubleshoot it for u? Maybe they can find out exactly what's wrong and how to fix it without u maybe spending a whole lot of unnecisarry cash. Then let us all know how u do.
A molex looks different from those connections to a hard drive. It's not a big 4pin block, but a smaller very flat connction with seven connection points like those u would see in a usb connection. It's not the same as usb though either.
Maitai is offline   Reply With Quote
Old August 15th, 2007, 12:44 PM     #19 (permalink)
A molex looks different from those connections to a hard drive. It's not a big 4pin block, but a smaller very flat connction with seven connection points like those u would see in a usb connection. It's not the same as usb though either.[/quote]
oh, well i mean the 4pin block. i sent back my card and brought a whole new kit. I now have a quad core, 4 gb of ram, a p965 platinum motherboard and the same graphics card. they are all arriving today. I got mwave.com to assemble and test the board and processor before they gave it to me so i know that wont be the problem. i also got a coolmax 600w power supply (i know people don't like coolmax but the reviews were positive) and hopeful in a few hours i will have a working pc...hopefully
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Radeon X1950 Pro problem jdowny Technical Support 18 November 22nd, 2007 10:43 AM
Anyone with a x1950 pro? Maitai Graphics Cards and Displays 6 August 2nd, 2007 07:13 AM
Reading Temp x1950 Pro ChubTub Graphics Cards and Displays 2 July 26th, 2007 01:34 PM
Lockups with my new x1950 pro Eyedore Graphics Cards and Displays 8 February 11th, 2007 04:47 PM
ATI X1950 Pro Length ragtop Graphics Cards and Displays 9 January 30th, 2007 08:38 PM
Is It Just Me? (640)
Video card compatability. (7)
Is this a good laptop for gamming? (6)
Bought an AGP "HIS Radeon HD 3.. (18)
Outlook add-in won't remove. (9)
Presario Help (6)
Misery Loves Company... (1873)
Putting together my wish list (17)
Folderchat: The Holiday thread (156)
File associations (3)
Best Boot Drive Imaging Softwar.. (4)
New info on the Phenom II X4 (33)
[Help] Computer Freeze (3)
is there a way to Grep for a sp.. (6)
Automatic Updates Turns off Aut.. (10)
Is this a good laptop for gammi.. (6)
Giga Pocket Junk (1)
Seald copy of windows 95 for sa.. (1)
