Thread: Texture / poly "tearing" problem
March 3rd, 2008, 05:16 AM #1Junior Member
- Mar 2008
- 2
I was wondering if anyone could help me out.
I've been playing Warcraft on this PC for the last year, all fine. Nothing has changed - I'm tech savvie enough to know what my pc is and isn't doing - but suddenly and seemingly at random, I'm noticing polygon and texture stretching and disruption.
Here's a grab:
http://img337.imageshack.us/img337/6...8231855ua7.jpg
You can see the misplaced lines and so on. It really seems to affect trees. It seems to happen totally at random with no real thing to make me think "thats causing it". Sometimes it will happen after 5 mins, sometimes after an hour.
Alt tabbing to the desktop and back seems to remove it for a random amount of time, as does the game having to load a transition screen.
The laptop is an Alienware Area 51 and the card is a gf go 7600 with latest driver.
Many thanks
March 3rd, 2008, 11:07 AM #2
when this would be a laptop, I'd say check yer videocard for dust and overheating, but since this is a laptop, that is kinda hard.
is it possible for you to check the temps?? I've seen this before, and usually it was the ram on the videocard, due to failure, or overheating.2 x Opteron 4280 2.8Ghz, Asus KCMA-D8, 32GB DDR3 1600, Asus 6950 DCII 1GB 2 x M4 64GB SATA600, Caviar Black 640GB, Seagate 1TB, 27"syncmaster
By kevinauld in forum Graphics Cards and DisplaysReplies: 0Last Post: March 3rd, 2008, 05:16 AM -
How do I disable the "power", "sleep", and "wake" buttons.
By ShawnD1 in forum General Tech DiscussionReplies: 1Last Post: January 30th, 2004, 11:50 AM -
PCChips M577 Motherboard help..are "keylock" or "turbo" connectors needed to boo
By John Prophet in forum MotherboardsReplies: 8Last Post: July 24th, 2002, 04:43 PM -
Remember the "Worm", "Cave", or "Ribbon" games?
By SickPup404 in forum IMO CommunityReplies: 11Last Post: July 10th, 2002, 07:02 PM
BTW, if the transmission is not computer controlled, and especially if the engine is running a carb, take a look at the kickdown linkage as well.
