Join TechIMO for Free!
Thread Tools
Currently Active Users: 2232
Discussions: 186,586, Posts: 2,226,785, Members: 230,212
Old May 12th, 2008, 02:01 AM   Digg it!   #1 (permalink)
Help with graphics card upgrade
Hey guys,
Let me first say that I'm not exactly a computer expert, although I feel comfortable enough to install basic components (i.e. ram, etc.). Basically, I'm looking to upgrade the graphics card on a new Gateway GT5656. I had been planning on upgrading to this card: http://www.newegg.com/Product/Produc...82E16814130082 , but I'm worried that it will be either 1) too big 2) too high maintenance for my 300W power supply. So, I'm wondering if you guys can help me out by giving me some advice on a good card that I could run Age of Conan with medium to high settings.
By the way, here are a couple images I took of my computer's insides:
Sorry for the poor quality, but my camera's battery had died and I had to use my Blackberry's camera. If you guys need any more information I'd love to give it to you.
Thanks!
P.S. Looking to spend under $200.
scoris is offline   Reply With Quote
FREE instant scan
Old May 12th, 2008, 02:35 AM     #2 (permalink)
Banned
Keymaker's Avatar
Send a message via ICQ to Keymaker Send a message via Yahoo to Keymaker
These are your system specs. I take it? http://review.zdnet.com/desktops/gat...-32865771.html
Looks like PCI-E 16x
It would work, it will just take up two spaces. the PCI Express x1, 2 slot. However, you need a minimum of 400 watt PSU.
Keymaker is offline   Reply With Quote
Old May 12th, 2008, 04:33 AM     #3 (permalink)
Hey thanks for the quick reply! I do have additional questions though. They are:
1. How expensive would it be to upgrade the power supply? I'm not sure I'd be comfortable doing it myself, because if I screw something up then I'm stuck without a computer for a long time.
2. I just realized that PCI-e 2.0 is backwards compatible, so the original video card I was looking at would comply with my system. The card is: http://www.newegg.com/Product/Produc...82E16814150252 . However, am I going to run into the same problems with the power supply? I'd rather not upgrade the power supply, fans, etc. if I can avoid it until later on. So, would I be better off going with something like this: http://www.newegg.com/Product/Produc...82E16814150229 ?
By the way, I run my resolution at a max of 1280 x 1024 but rarely go that high. Also, any other recommendations would be really helpful. I really appreciate all the help!
Old May 12th, 2008, 09:39 AM     #4 (permalink)
Looking at your system specs, I am wondering what level card you will need. The 9600gt is essentially the same card as the 8800gt, just stepped down a bit, but I doubt it is a difference you will notice. I don't know this part for sure, but I think it may have slightly less power consumption as well. I have heard people running after market cards on the stock psu's, it might not work, but it may be worth a try.
Installing a different psu won't be particularly hard, though it will be somewhat time consuming, ie, not a five minute fix like a gfx card or ram, etc.
Gigabyte P35 DS3L, Intel E6550 @3.25ghz
4gb DDR2 1066, EVGA 8800GT 512mb,
Cool Master RC-690, WD Raptor 150gb, WD 500gb and 250gb AAKS
thephilosophizer is offline   Reply With Quote
Old May 14th, 2008, 04:04 AM     #5 (permalink)
Send a message via AIM to RamonGTP Send a message via Yahoo to RamonGTP
The 9600GT isn't really the same as a 8800GT. Sure they perform closely with the 8800GT in some scenario's, there is a significant difference once you go up in resolution and/or are running a game that is shader heavy.
That said however, I do agree that the 9600GT is the best card for the guy given that his max res is 1280x1024 and he's only got a 300watt psu to work with. At the resolutions he's running, the difference between the 9600GT and 8800GT would be minimal.
RamonGTP is online now   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Graphics Card Upgrade alan_mcc Graphics Cards and Displays 0 February 5th, 2008 10:18 AM
Graphics Card Upgrade Help dzee Graphics Cards and Displays 15 December 15th, 2006 11:55 AM
Graphics Card Upgrade simoncpage Graphics Cards and Displays 15 April 23rd, 2006 08:28 AM
Graphics card upgrade tnbain Graphics Cards and Displays 9 October 19th, 2004 08:33 AM
Graphics Card Upgrade Xeroid Graphics Cards and Displays 5 February 29th, 2004 12:04 AM
Is It Just Me? (480)
Why Does the MOON Grow Bigger as It.. (7)
Happy Birthday Atomic Rooster (9)
Connected to LAN but unable to use .. (5)
1 internet. 1 house. 3 computer. ho.. (8)
Folderchat: The Holiday thread (108)
xbox setup help. HDMI-DVI-VGA. (0)
HOWTO: Openvpn and Ubuntu (Dapp.. (40)
SSD's, RAID, and External Backu.. (4)
pc freezes randomly (9)
Laptop doesn't stay connected t.. (3)
1 internet. 1 house. 3 computer.. (8)
old photos and files from e mac.. (2)
Need to retrieve files from a v.. (1)
