Join TechIMO for Free!
Thread Tools
Currently Active Users: 2243
Discussions: 186,587, Posts: 2,226,789, Members: 230,212
Old August 29th, 2008, 10:48 AM   Digg it!   #1 (permalink)
Samsung T220 22" monitor not working...
Hello,
I bought a Samsung T220 22" monitor today, and made sure it's functioning properly @ the store.
When I got home and plugged it in (I've tried DVI, then unplugged and tried D-sub, both gave me the same result) it went blank, and the led began to flicker slowly...as if it is asleep or something...
Does anyone know how I can get it to work? It's really important for me.
Thanks in advance!
-Offir.
Offir is offline   Reply With Quote
FREE instant scan
Old August 29th, 2008, 10:52 AM     #2 (permalink)
Mobile Member
ShuckyD's Avatar
Are you sure your computer is sending a signal to the DVI port? Is this the first time you are usnig a DVI monitor with your computer?
Thinkpad T61 14.1 wide | WinXP Pro | Intel C2D T8300 2.4ghz CPU | 3GB DDR2
AGN WiFi, BT, WWAN | 256mb NVS140 graphics | 160GB 7200RPM HDD
ShuckyD is offline   Reply With Quote
Old August 29th, 2008, 11:00 AM     #3 (permalink)
Yes, I have a Geforce 8800GT card and I've plugged this monitor before...
The thing was that I bought the monitor, didnt check it, came home and discovered there's a burnt pixel line on it - it was working properly, displaying everything.
Then I went there and had it replaced, checked that it's working and not faulty, and went back home to install it. That's when I got the blank screen and the led flickering...
I'd like to mention that when the screen isnt plugged in it shows a "Check Signal Cable" message that hops around all over the screen, which means the monitor itself is working properly...my issue is with the computer
Old August 29th, 2008, 11:03 AM     #4 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Make sure the monitor is plugged in correctly.
Also try a different DVI port.
http://www.ubuntu.com
Old August 29th, 2008, 11:06 AM     #5 (permalink)
I did both. It is plugged in correctly and tried both ports.
I'd also like to mention that Im running my old screen on the same port, and my current screen works just fine, but when I replace it with the Samsung (at the same port) the Samsung isnt working...
Old August 29th, 2008, 11:30 AM     #6 (permalink)
Mobile Member
ShuckyD's Avatar
Make sure (which I'm sure you did, I'm just checking) all the cables are secure on the monitor, including its power, etc. Also, since you just bought it today, would you be able to return/exchange it from the store?
Old August 29th, 2008, 02:15 PM     #7 (permalink)
I did make sure of all of that, now here's the fun part:
I turned the computer off for 15 minutes, turned off the monitor as well, plugged the monitor...
After 15 minutes I turned on the monitor then the computer...working like a charm.
Is there any logical explanation to this? Or is it just one of those ghost bugs in machines?
Old August 29th, 2008, 05:30 PM     #8 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Maybe the Power wasn't working properly, and now it is.
Not enough voltage to the monitor.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Samsung T220 22" LCD Monitor Problems Unfetteredboi Graphics Cards and Displays 7 June 5th, 2008 08:23 AM
Samsung 930b 19" monitor? Sixpac_XP Graphics Cards and Displays 2 September 3rd, 2005 11:59 PM
19" LCD monitor: Samsung or Planar? videobruce Graphics Cards and Displays 6 January 6th, 2004 08:15 AM
Opinions on Samsung 19" 955DF Monitor sKiT Graphics Cards and Displays 9 August 4th, 2003 05:32 PM
19" samsung 955DF monitor $152 shipped John Prophet ResellerRatings Homepage Deals 16 December 9th, 2002 09:00 AM
Is It Just Me? (483)
Why Does the MOON Grow Bigger as It.. (7)
Misery Loves Company... (1847)
Connected to LAN but unable to use .. (5)
1 internet. 1 house. 3 computer. ho.. (8)
Folderchat: The Holiday thread (108)
problem with logitech 440 speak.. (0)
xbox setup help. HDMI-DVI-VGA. (0)
HOWTO: Openvpn and Ubuntu (Dapp.. (40)
SSD's, RAID, and External Backu.. (4)
pc freezes randomly (9)
Laptop doesn't stay connected t.. (3)
1 internet. 1 house. 3 computer.. (8)
old photos and files from e mac.. (2)
