Results 1 to 9 of 9
    Member KevinsHope's Avatar
    Apr 2010
    Greenville, OH, USA
    119
    PLEASE help! Graphics card issue or PSU issue?
    Hey,
    So...one problem at a time, I'm getting closer to getting this graphics card up and running. I am trying to get a used Nvidia Geforce 285 GTX up and running. Got it intalled. Got the driver installed. Bought a new power supply for it. I'm getting a message at the beginning of windows start up that says that the card is not recieving suficient power, and that the settings will be lower on the card to allow it to run. Games and stuff run like crap with it's "adjusted" settings.
    So...here we go. I'm lost again. I have a Antec 750 W PSU model EA-750.
    Specs are as follows
    +5v= 25A max
    +3.3V=25A max
    ALL +12v (1-4)= 25 max each
    -12v=0.5A max
    +5vsb= 3A Max
    It says undernieth the chart
    +12v1, +12v2,+12v3,+12v4 max load = 56A
    Is the power supply not enough or is the card not doing its job?
    Minnesota
    17,359
    do you have both the 6 pin PCIE power connectors from the Power supply plugged into the Video card?
    Apr 2010
    Greenville, OH, USA
    119
    Thanks for your response, ShyguyXPC.
    This card has a six pin and an 8 pin jack side by side. I had both the pcie 6 pin and the pcie 8 pin plugged in. There is another 8 pin jack that says p4 on it. At one point, I tried hooking it up along with the 6 pin PCIe, but the card won't run with that 8 pin p3 plugged in. I was thinking it might be the 56A limmit the power supply has. I also have two DVD roms and two hard drives running on the 12v railing, along with 5 different cooling fans. I have no idea how much any of those use in Amps, but maybe their combined usage is more than the graphics card leaves available. I read that the graphics card uses 47A, so that doesn't leave much breathing room if I am understanding it all correctly. Is this the issue, Maybe? What do you all think?
    GA
    5,409
    Try reseating your 6 & 8 pin PCIe plugs in the card again. Double check that the 8 pin is for PCIe and not one of the "P4" CPU plugs.
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    I'm not sure where you got 47 amps.
    The tests I found show total system as
    257w
    305w
    381w
    385w
    Lets take the 385 Watt total system.
    If that was all 12v (and it isn't) total 12v would be 32amps
    That power supply should be way more than enough even for dual cards .
    Hard Sayin Not Knowin
    Minnesota
    17,359
    Quote Originally Posted by KevinsHope View Post
    This card has a six pin and an 8 pin jack side by side. I had both the pcie 6 pin and the pcie 8 pin plugged in. There is another 8 pin jack that says p3 on it. At one point, I tried hooking it up along with the 6 pin PCIe, but the card won't run with that 8 pin p3 plugged in. I was thinking it might be the 56A limmit the power supply has. I also have two DVD roms and two hard drives running on the 12v railing, along with 5 different cooling fans. I have no idea how much any of those use in Amps, but maybe their combined usage is more than the graphics card leaves available. I read that the graphics card uses 47A, so that doesn't leave much breathing room if I am understanding it all correctly. Is this the issue, Maybe? What do you all think?
    Well if your running near max for you PSU with that system configuration, then I must be pushing my PSU to its limit (read in my first post, my sig, has all of my hardware for my main rig, and I'm running on a Corsair 750W PSU with 60A Total Single 12V Rail...)
    Seriously though, your not hitting ANYWHERE near the max for your PSU with what your saying for hardware components.
    like JLK said, make sure your not using the 8 (or sometimes its a 4x4) plug thats intended for the CPU.
    Looking up your PSU, you should have two 6 pin and two 6+2 Pin plugs for PCIE.
    the 6+2 is the same as a 8 pin PCIE, just allows you to use 4x 6 pin if necessary.
    Apr 2010
    Greenville, OH, USA
    119
    Well...obviously, what I heard with the 47A was wrong. Sorry for that. However, I am certain that I used the PCIe 6+2 pin and a 6 pin PCIe in connection with the card. I tried using one off of each cord and running the GPU off of one cord. It is good to hear that the power supply should be sufficient. So what does it mean that the well connected PCIe 6+2 pin and the 6 pin PCIe did not provide the power that the GPU requires. Are you guys thinking the GPU is bad?
    (AKA) Nakamura sweeper2's Avatar
    Nov 2003
    5,737
    sounds that way...what is the "actual" brand of this nvidea card ... (example) eVga, XFX, etc etc ... or is it a straight up nVidea card ...?
    If the PSU is new .... have you tried only powering up 1 hard drive the motherboard, and the card to see if it boots correctly .. I would recheck all pins on the card.. and the female part of the plugs from the psu ... make sure when you push the plugs in, it's not pushing some of the wires out of the (psu plug) ...
    Apr 2010
    Greenville, OH, USA
    119
    Quote Originally Posted by sweeper2 View Post
    Yeah...tried that. No dice. I got a psu with a singly 12v thread that maxed at 76A....still no dice...and then...to top it all off....I discovered in Direct X that it is a gtx 280...not a gtx 285, though it was advertised as a 285, which would be irritating but exceptable if it worked right. But it doesn't work right, so I'll be asking Ebay to return my money, and they can chase down the jerk wad that sold this to me. I'm going to push to have his or her account suspended...I'm so ticked. This seller sells a lot of PC stuff on Ebay. For any of you out there that are ebayers, I think her name is Sarah Barnes and she goes by the handle sbar6556, at least unitl they suspend her account and she has to invent a new alias. If you know her, be sure to send her a nasty virus for me!
  1. New Graphics Card Issue - Help!
    By eXiilez in forum Graphics Cards and Displays
    Last Post: February 21st, 2010, 03:48 PM
  2. Graphics card issue...
    By Raimiette in forum Technical Support
    Last Post: October 23rd, 2009, 10:52 AM
  3. graphics card issue
    By quaddamage in forum Graphics Cards and Displays
    Last Post: September 1st, 2009, 09:34 PM
  4. New build graphics card issue
    By Newagebuilder in forum Technical Support
    Last Post: August 29th, 2009, 08:28 PM
  5. graphics card driver issue
    By gravesad in forum General Tech Discussion
    Last Post: December 4th, 2008, 10:51 AM
