Thread: Dying Power Supply Signs?
September 18th, 2010, 04:38 PM #1Junior Member
- Sep 2009
- 28
For the past month or two, every time I powered on my PC, there was to signal/power transferred to the monitor. I tried switching out the power cables for both the PC and monitor, to no effect.
Just the other day however, without any changes made, the PC has stopped working entirely. I switched out the cables, surge protector, and tried separate wall outlets. Nothing can get it working again. Was the monitor issue showing signs that the power supply was dying out, and what methods can I use to check for other potential issues?
September 18th, 2010, 07:38 PM #2
All you can do is the same thing a computer shop would do.
You have to substitute parts, for the power supply you have to try yours in a known working computer or try a working power supply in yours.
You can test the memory and hard drive with software, but everything else is tested by the above method, except the motherboard, and that, through the process of elimination, if every thing else checks out, it's the motherboard.
edit
More info needed, like exactly what happens, if anything, when you push the start button.
Specs?
Video card or on-board, or both?
Any expansion cards, or is everything, on-board?
The trouble with computer diagnosis, is the symptoms all overlap, and your monitor problem and or not starting, could be PS, video card, memory, CPU, motherboard, or any expansion card.
They might not even be related, and it is as simple as the start button.
Maybe, I can rule out the hard drive, but then again a short in the hard drive could cause it not to start.Last edited by stroyal; September 18th, 2010 at 10:50 PM.
Hard Sayin Not Knowin
Power supply dying..or something else?
By Micca in forum Technical SupportReplies: 4Last Post: September 6th, 2008, 05:25 PM -
Cooler Master Real Power Pro 1250w Power Supply Review
By RobRich in forum Tech News DiscussionReplies: 0Last Post: August 11th, 2008, 12:53 PM -
Cooler Master Real Power Pro 850w Power Supply Review
By RobRich in forum Tech News DiscussionReplies: 0Last Post: April 18th, 2008, 09:32 PM -
showing no signs of power...but power source is fine
By tonymont in forum Technical SupportReplies: 7Last Post: June 25th, 2007, 10:55 AM -
Is my Power Supply dying or MB?
By Chuckiechan in forum Technical SupportReplies: 11Last Post: September 5th, 2002, 10:31 PM
Thats pretty bad, stopping to pose with a friend or someone while that crap is going on in the background. Peoples lives being destroyed, lives being taken, etc, and they have time to stop and pose...
