February 7th, 2011, 07:06 PM #1Junior Member
- Feb 2011
- 2
Need Help With Upgrading Graphics Card
I have a terrible graphics card. Its an Intel (R) g43/g45 Chipset.
It came with the desktop i bought, which is a dell inspiron 560 with a Intel® CoreTM 2 Duo E7500 (2.93GHz/1066Mhz FSB/3MB cache) and 300 Watt supply.
Im looking for help with getting a new graphics card, nothing fancy, as long as it is better than a GeForce FX 5600. My friend recommends a GT240 which is cheap and works better, but it is @ 350 watts. will this mess up my computer?
February 7th, 2011, 07:13 PM #2
Ugh...
Your current Graphics "Card" is onboard Intel Integrated Graphics.
As to the GT 240 IT IS NOT 350W...
Even some of the top end cards these days barely pull 300W.
GT 240 doesn't even pull 75W (Pulls about 70W total) which is the max the PCI Express x16 slot can feed to a card.
it may be recommended to have a 350W Power supply for the ENTIRE System with a GT 240, but the card itself does not need 350W.
Just about ANY graphics card these days, even the most lowest end for current generation cards will be more powerful than an Ancient GF FX 5600.
but a GT 240 should be a MASSIVE increase in performance compared to that or even the crap onboard intel graphics (which are not suited for most 3D gaming)
Your Current system, based on the CPU specs you listed, should be capable for Running GT 240 just fine.
Is your Current system a Regular Size Case, or a Slim Case (not sure if the Dell Inspiron 560 was available in Slim style or not)
Also open up your PC and look at the Power supply, find a Label on it and look for the Amp Rating for the +12V Power on the Power Supply, just to make sure it has enough to run a GT 240.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
February 7th, 2011, 07:37 PM #3Junior Member
- Feb 2011
- 2
By mr.isaac in forum Graphics Cards and DisplaysReplies: 16Last Post: January 13th, 2011, 08:28 PM -
Upgrading PC-Is this graphics card ok?
By Intheuk in forum Graphics Cards and DisplaysReplies: 6Last Post: March 17th, 2009, 01:33 PM -
upgrading graphics card
By Vealy666 in forum Graphics Cards and DisplaysReplies: 2Last Post: January 29th, 2009, 11:39 AM -
By HornetX7 in forum Graphics Cards and DisplaysReplies: 13Last Post: November 5th, 2008, 02:39 AM -
Upgrading a graphics card
By gef2003 in forum Graphics Cards and DisplaysReplies: 18Last Post: April 24th, 2007, 02:26 PM
I don't know how to open up a pc, but I think that it will work, hopefully.
Inclement weather is preventing me from riding my bike, so it might as well be snowing.
