Results 1 to 5 of 5
    Dec 2011
    2
    HELP SWTOR Graphic Dual Graphics cards. HELP
    Hey everyone i need some help with finding out a graphics card to buy. I have about 80$ and i want to get a card for SWTOR so i can run it in 1920x1080p with medium-high graphics, at around 40+ FPS at all times. I'll link my specs below. Let me know if i'd be better of buying just a single card due to my power supply or anything else.
    Computer Case : Rosewill Challenger Black Gaming Case
    Power Supply : Cosair CX600 Watt Power Supply
    Motherboard : Biostar A880G+ AM3 AMD Motherboard
    DDRMemory : G.Skill RipJaws 4GB (2 X 2GB) DDR3-1333 PC3-10666
    Processor : AMD Phenom II X4 955 3.2GHz AM3 Quad Core 8MB Cache
    CPU Cooling Fan : AMD Copper HeatPipe Extra Quite Fan
    Hard Drive : 1TB Seagate Barracuda 7200RPM SATA 6 Gb/s 32MB Cache
    Video Card : ATI Radeon HD 4250 Onboard 3D graphics
    DVD Recorder : Sony 24X DVD+/-RW
    Sound Card : Built-in HD 6-Ch Sound Card
    Network Card : Built-in Gigabit LAN
    Dec 2011
    2
    Also, how do i know if i can even have 2 cards. lol?
    Jan 2003
    Outside the box
    8,489
    4
    First things first, your motherboard only supports one pci-e slot and only one gpu. You don't have sli or crossfire support so running two cards wouldn't happen. Second if all you can afford is $80 for the upgrade then you wouldn't run to run two $40 cards anyways. You'd get much better performance out of a single $80 card that you would two really low end $40 cards.
    That said I'm not really familiar with SWTOR or how demanding it is but I would kind of doubt you'll get the performance you are looking for out of an $80 card. You might though. Here are a couple options
    Newegg.com - XFX HD-657X-ZNFQ Radeon HD 6570 1GB DDR3 PCI Express 2.1 x16 HDCP Ready Video Card
    Newegg.com - GIGABYTE GV-R667D3-1GI Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card
    Newegg.com - XFX HD-667X-ZHF3 Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card
    Minnesota
    17,377
    for $80-ish in price, this is about as good as you can get, its refurbished, but its even more powerful than any of the "New" in box cards rich listed:
    PowerColor Radeon HD 5770 512MB DDR5 PCI Express (PCIe) DVI/VGA Video Card w/HDMI & HDCP Support PowerColor AX5770-512MD5-H Radeon HD 5770
    Nov 2006
    Portsmouth, UK
    4,159
    Any of the suggested GPUs will run the game just fine. Really doesn't take much to run and keep it in the high 90s...
  1. dual graphics cards for three screens
    By waquar in forum Graphics Cards and Displays
    Last Post: February 25th, 2009, 05:46 PM
  2. Dual core processor - Dual pci-e graphics cards?
    By skagman1001 in forum Graphics Cards and Displays
    Last Post: November 18th, 2006, 12:11 PM
  3. dual graphic cards
    By drunkenmunky101 in forum Graphics Cards and Displays
    Last Post: August 9th, 2005, 07:07 PM
  4. Dual Processor Graphics Cards
    By EvilRick in forum Graphics Cards and Displays
    Last Post: December 6th, 2001, 12:12 AM
