Thread: GeForce GTX560 Problems
April 14th, 2012, 01:45 AM #1Junior Member
- Apr 2012
- 4
I recently bought a Nvidia Geforce GTX560 graphics card, I uninstalled the drivers and everything from the previous card, and put the new card in.
Inserted the CD, the auto run didnt pick it up so i opened it manually and went into the UI. When the UI opened I clicked drivers, it flicked for abit then said graphics card has been successfully installed and rebooted.
When it booted back up it was still in the 900 odd resolution and found out that it wasnt installed.
I have checked that the card is in properly and is connected to power.
I need help getting this to work, so if specs or anything is needed, ask how I get it and ill post here.
April 14th, 2012, 01:48 AM #2Junior Member
- Apr 2012
- 4
Version 270.48
Nvdia Installer cannot continue
April 14th, 2012, 02:16 AM #3
Download, install a driver cleaner program like this one Phyxion.net - Driver Sweeper
run it, remove the old display drivers and any of its associated drivers (for example with Nvidia, remove Display Drivers, PhysX, and 3D Vision, etc)
Make sure you have the latest Drivers downloaded and saved to the desktop first though.
DO NO use the old drivers on the CD unless you have to, their outdated.
Go to nvidia's website, and download the latest drivers for your Video card, and Version of Windows you are running.
Run the driver cleaner, uninstall the drivers, and what not.
reboot the PC, let windows load and install its default VGA drivers, then if it asks to install or search the web to install the drivers for your card, cancel that, find the driver package on your desktop, double click it to install it, install everything you need (3D vision can be skipped if your only using a single display or now 3D glasses),
If windows has to reboot one more time, do so, if not, then just set your res you want for your desktop and you should be good to go.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
April 14th, 2012, 02:37 AM #4Junior Member
- Apr 2012
- 4
I downloaded the Driver Sweep and cleaned all of the Nvidia things.
I checked the Chipset, Display and Physx, went analyze and clean.
I rebooted the computer and ran it again and it can still find 1, which is Nvidia Display, might be because I have the graphics card in the slot?
As for the drivers I downloaded the Geforce > GeForce 500 series > Windows 7 64-bit > English US.
April 14th, 2012, 02:45 AM #5Junior Member
- Apr 2012
- 4
Nvidia installer cannot continue.
I dont have the monitor plugged into the card as when I boot it up, the light on the monitor just flashes and a black screen.
GeForce GTX560 Drivers wont install.
By aclmacca in forum Graphics Cards and DisplaysReplies: 46Last Post: January 4th, 2012, 08:35 AM -
GTX560 problem
By midnan in forum Graphics Cards and DisplaysReplies: 14Last Post: November 8th, 2011, 05:30 PM -
GeForce 7600GS Problems!!
By Games Goblin in forum Graphics Cards and DisplaysReplies: 9Last Post: April 12th, 2007, 05:50 AM -
GeForce Fx 5500 Problems
By zimsk8er in forum Technical SupportReplies: 10Last Post: May 30th, 2006, 08:36 PM -
Geforce 2 Ti problems...HELP!!
By ariahokas in forum Graphics Cards and DisplaysReplies: 7Last Post: May 27th, 2003, 12:04 PM
AMD has dropped to fourth in the microprocessor sales rankings due to demand for mobile device processors, with Qualcomm and Samsung substantially boosting their sales of ARM chips.
AMD Fourth in Microprocessor Sales
