Thread: Texture problem!
May 6th, 2012, 04:28 AM #1Junior Member
- May 2012
- 20
Texture problem!
I have this problem with every game,
it looks like there are parts of textures missing. Please help.
May 6th, 2012, 03:14 PM #2
We need your computer specs and OS! Have you tried updating the graphics card driver?
May 7th, 2012, 12:55 PM #3Junior Member
- May 2012
- 20
Well this problem just occurred out of nowhere!
I was able to play all the games but than just BAM all games are glitched. Except the java running Minecraft!
I got a Radeon HD 4300/4500 series, a Pentium Dual-Core CPU E6500 @ 2.93GHz - 2936 MHz - 2 core('s) logical processor.
Win 7 Home Premium 64x bit
May 7th, 2012, 02:01 PM #4Junior Member
- May 2012
- 20
I think it could be a problem caused by the Catalyst Control center of my defraggler from piriform.
May 7th, 2012, 02:03 PM #5
If the video driver reinstall/update fails to help, then try to reinstall DirectX.
I hope it isn't a hardware problem on the card, though.
May 7th, 2012, 02:06 PM #6Junior Member
- May 2012
- 20
How can I do that?
May 7th, 2012, 02:50 PM #7
May 8th, 2012, 09:39 PM #8Junior Member
- May 2012
- 1
I have the same exact problem
I also have this problem. I have an ATI Radeon 3000 integrated graphics card. This also happened about 2 days ago.
May 26th, 2012, 05:26 AM #9Junior Member
- May 2012
- 2
this started to happen as soon as I replaced my motherboard
here is some examples
a strange thing that happens is when i tab out of the game and come back to it the game looks fine but when i start moving around the game creates more of these errors
May 26th, 2012, 05:59 AM #10Junior Member
- May 2012
- 2
i believe its because im using hardware acceleration and not software acceleration
May 26th, 2012, 02:49 PM #11
Hardware acceleration wouldn't cause that, its faster and better performing than Software which is processed by the CPU, the Hardware is GPU Processing.
With out posting ANY of your hardware specs or what it was that you replaced aside from your motherboard, no one can help you solve the problem.
We're not Psychics here, so you will have to post info that can help us help you.
Also, start a new thread, rather than jack someone elses which still has yet to be solved.
Though its similar symptoms as yours, it could be an entirely different problem, and until this users issues are resolved, it would make sense to just have your own thread to refer to, instead of us dealing with multiple users problems in one thread adding confusion to people reading or posting their problems in here.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
May 29th, 2012, 02:00 AM #12Junior Member
- May 2012
- 20
I already fixed it, it was caused by a wrong version update of catalyst control center.
July 17th, 2012, 08:53 AM #13Junior Member
- Jul 2012
- 1
I found out how to fix it. If you have AMD catalyst control center. Just uninstall it and it should work fine it worked for me.
July 17th, 2012, 02:03 PM #14
yeah.....
Apparently you didn't read the thread starters reply above yours, stating the same dang thing.
If they had a wrong update version, they would have had to reinstall or update the drivers, which is more or less the same thing you suggested. In any case its a moot point since they stated they already solved the problem.
As they say, "Okay people, move along, nothing to see here, just move along, Thank You."i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
Video Problem Texture maps swap in game then freeze.
By pscbird@verizon. in forum Technical SupportReplies: 2Last Post: July 6th, 2011, 03:21 PM -
Texture / poly "tearing" problem
By kevinauld in forum Graphics Cards and DisplaysReplies: 1Last Post: March 3rd, 2008, 11:07 AM -
By kevinauld in forum Graphics Cards and DisplaysReplies: 0Last Post: March 3rd, 2008, 05:16 AM -
AGP Texture Acceleration problem
By Muhka in forum Technical SupportReplies: 3Last Post: October 11th, 2007, 09:53 PM -
Texture compression
By Parts in forum Graphics Cards and DisplaysReplies: 2Last Post: February 17th, 2002, 02:57 AM
Inclement weather is preventing me from riding my bike, so it might as well be snowing.
