Results 1 to 6 of 6
Thread: Display Problem
    May 2012
    4
    Display Problem
    Dear Friends,
    i am facing the display problem, but i can't explain in words, i had taken a photograph of the screen but i don't know how to attach here? please help me.
    Frick tony_j15's Avatar
    Mar 2003
    Joplin, MO
    14,096
    Hi, sanjdar.
    Click "post reply" then scroll past the "reply to thread" box down to the "additional options" box. Click "manage attachments" then browse for the file upload it, and post the reply.
    Hope that helps.
    Good job, friend-of-friends!
    May 2012
    4
    thanks tony_j15 for your help.
    I have attached screen shots of the problem. please give a solution.
    thanks in advance.
    Attached Thumbnails Attached Thumbnails Display Problem-screen1.jpg   Display Problem-screen-2.jpg
    Mar 2003
    Joplin, MO
    14,096
    This looks like a hardware problem. One cause can be the cable that connects the video chip to the screen has been pinched/damaged, causing the display to show the color bands. More likely, in my opinion, is the video chip itself is damaged from overheating or the memory attached to it is going bad.
    If possible, take it in to a service center for diagnosis. I do not think there is an easy software fix or patch that you can do to solve this. It will likely involve a bit of cash and getting the motherboard and/or the screen replaced.
    May 2012
    4
    Quote Originally Posted by tony_j15 View Post
    I sent the same photographs to authorized Apple service centre but they are not replying, or answering my phone calls.
    I done the basic hardware test, holding down the D key while booting. There were no hardware problem in the result.
    I think what you are saying is right.
    I will do the test again using "Perform extended testing" option. and will post the results.
    I tried reinstalling the OS but not happening.
    May 2012
    4
    dear tony_j15, as i mentioned in my earlier post that i will try "Perform extended testing" option.
    surprisingly!!!! it worked out........ my MacBook Pro is working properly now.
    Thanks for the help.
  1. DISPLAY PROBLEM
    By YOUSEF in forum Technical Support
    Last Post: June 30th, 2009, 04:01 PM
  2. display problem, help please?
    By optinox in forum Graphics Cards and Displays
    Last Post: February 24th, 2006, 05:10 PM
  3. Display Problem
    By enuff1 in forum General Tech Discussion
    Last Post: May 30th, 2005, 12:17 AM
  4. display problem
    By natbeys in forum Graphics Cards and Displays
    Last Post: August 30th, 2004, 10:05 PM
  5. Display problem
    By MitaDC in forum Graphics Cards and Displays
    Last Post: October 3rd, 2003, 02:52 PM
