Results 1 to 4 of 4
    May 2012
    3
    Help with Graphics Card
    Hi,
    Can anyone help me with my issue? I would like to upgrade/change my Graphics Card but do not know what will be compatible with my system components. The main reason for upgrade is for using with various 3D design software. Below I've included my system report, hope it was not to lengthy, because I didn't know what really to include.
    Thanks in advance. Awaiting a response.
    System Information Report
    General
    Operating System Microsoft Windows XP Professional
    System Type 32 bit
    Central Processor Turbo 4000+ Comb (K8M80-M7A and Sempron 2500+)
    User Name
    Graphics
    Video Adapter VIA/S3G UniChrome Pro IGP
    Video Memory 64.00 MB
    Screen Resolution 1280 x 768
    Video Adapter LogMeIn Mirror Driver
    Video Memory Unknown
    Screen Resolution NULL x NULL
    Storage
    Total Memory 1.44 GB
    Free Memory 454.26 MB
    Total Hard disk 149.05 GB
    Free Hard disk 54.00 GB
    Operating System
    OS Name Microsoft Windows XP Professional
    OS Version 5.1.2600
    Service Pack 3.0
    Product ID
    System Up Time 5/22/2012 8:49:45 AM
    Internet Explorer Version 8.0.6001.18702
    Microsoft DirectX Version 4.09.00.0904
    OpenGL Version 5.1.2600.5512 (xpsp.080413-0845)
    Memory Resource
    Used Memory 1014.41 MB
    Free Memory 456.01 MB
    Memory Usage 68%
    Physical Memory
    Memory Bank Bank0/1
    Description Physical Memory 0
    Device Locator A0
    Capacity 512.00 MB
    Speed NULL Mhz
    Manufacturer NULL
    Data Width 64 bit
    Memory Type Unknown
    Form Factor DIMM
    Physical Memory
    Memory Bank Bank2/3
    Description Physical Memory 1
    Device Locator A1
    Capacity 1.00 GB
    Speed NULL Mhz
    Manufacturer NULL
    Data Width 64 bit
    Memory Type Unknown
    Form Factor DIMM
    Central Processor
    CPU Name Turbo 4000+ Comb (K8M80-M7A and Sempron 2500+)
    Code Name Model 12, Stepping 2
    Manufacturer AuthenticAMD
    Current Clock Speed 1399 Mhz
    Max Clock Speed 1399 Mhz
    Voltage 1.5V
    External Clock 200 Mhz
    Serial Number
    CPU ID x86 Family 15 Model 44 Stepping 2
    Socket Designation Socket 940
    Internal Cache 128 KB
    External Cache 256 KB
    Motherboard
    Model K8M800-8237
    Manufacturer
    Serial Number
    BIOS Name Phoenix - AwardBIOS v6.00PG
    BIOS Vendor Phoenix Technologies, LTD
    SMBIOS Version 6.00 PG
    BIOS Date 9/26/2005
    BIOS Features
    ISA is supported Yes
    PCI is supported Yes
    Plug and Play is supported Yes
    APM is supported Yes
    BIOS is Upgradable (Flash) Yes
    BIOS shadowing is allowed Yes
    Boot from CD is supported Yes
    Selectable Boot is supported Yes
    BIOS ROM is socketed Yes
    EDD (Enhanced Disk Drive) Specification is supported Yes
    Int 13h - 5.25 / 360 KB Floppy Services are supported Yes
    Int 13h - 5.25 /1.2MB Floppy Services are supported Yes
    Int 13h - 3.5 / 720 KB Floppy Services are supported Yes
    Int 13h - 3.5 / 2.88 MB Floppy Services are supported Yes
    Int 5h, Print Screen Service is supported Yes
    Int 9h, 8042 Keyboard services are supported Yes
    Int 14h, Serial Services are supported Yes
    Int 17h, printer services are supported Yes
    Int 10h, CGA/Mono Video Services are supported Yes
    ACPI supported Yes
    USB Legacy is supported Yes
    AGP is supported Yes
    LS-120 boot is supported Yes
    ATAPI ZIP Drive boot is supported Yes
    IDE Controller
    Name VIA Bus Master IDE Controller
    Manufacturer VIA Technologies, Inc.
    Status OK
    IDE Controller
    Name Primary IDE Channel
    Manufacturer (Standard IDE ATA/ATAPI controllers)
    Status OK
    IDE Controller
    Name Secondary IDE Channel
    Status OK
    Video Adapter
    Name VIA/S3G UniChrome Pro IGP
    Video Processor VIA/S3G UniChrome Pro IGP
    Manufacturer VIA/S3G
    Video Architecture VGA
    DAC Type Internal
    Memory Size 64.00 MB
    Memory Type Unknown
    Video Mode 1280 x 768 x 4294967296 colors
    Current Refresh Rate 60 Hz
    Driver Version 6.14.10.0227-16.94.44.10
    Driver Date 6/9/2005 10:30:52 PM
    Minnesota
    17,361
    Um... wow...
    Here's the problem, your using onboard video.
    also no mention of the software being used.
    And with a lot of 3D rendering type software, unless its some of the newest stuff, most of that lies heavily on CPU power, with GPU only used for Preview renderings as you work on things.
    Your running Windows 32-bit which will limit you to 4GB max of System memory (Which includes not only RAM, but Video card RAM and other Cache memory in the system).
    Your running a Lowly AMD Sempron Single Core CPU with a low 1.4GHz Clock speed (an under powered CPU).
    This is your Motherboard: Biostar USA
    Any worth while video card upgrades you do will be 8x AGP Slot cards, which are hard to find these days and will cost MUCH MUCH more than is worth, since they are outdated.
    no brand makes AGP anymore and hasn't for years.
    Nvidia Stopped making them with the Geforce 8 series, and ATI/AMD Stopped with the Radeon HD 5000 series.
    We'd need to know the Software requirements that you are using to give any suggestions.
    We'd also need to know what your Power Supply specs are, not just the over all wattage, but the Brand, and Model of the PSU, and the +12V Amp rating on it, all of which should be found on a sticker or label on the PSU.
    Should also note, that your Motherboard can only use a max of 2GB of RAM, and you already seem to have 1.5GB of RAM.
    in order to max it out you'd need to remove the 512MB stick and place in a 1GB stick, but to be honest on a system this old, it really wouldn't be worth it. None of these upgrades would be unless you could get the parts dirt cheap.
    May 2012
    3
    Thanks my friend, I think I will get an all new up to date system all together.
    Minnesota
    17,361
    yeah, that would be best IMO.
    Especially when dealing with 3D rendering software, a much more powerful and Faster CPU will be very beneficial, same with a decent video card and plenty of RAM.
    As it is these days, $50 can get you a nice 8GB Chunk of DDR3 RAM.
    I currently run the hardware in my Sig above, and my newer system is very similarly spec'd with slightly faster RAM and a slightly faster Core i7 quad core.
    i7 920@2.66/Corsair H60//MSI X58 Platinum//6GB DDR3 1333//GTX 470//GTX285 For PhysX//HTO Striker 7.1//Corsair 750TX//CM 690 II Advanced//Win7 64//250GB, 2x250GB RAID 0, 500GB, 500GB
    Posted the sig specs above, since I'm going to be changing them to my new systems specs LOL, forgot to do that.
    but I run some 3D software on occasion, most of it Daz Software (Daz Studio 4 Pro 64-bit, Carrara 8 Pro 64-bit, Bryce 7 Pro, etc)
    and sadly sometimes I still run out of CPU resources when running and using large complex Mesh models, and often have Carrara or Daz Studio Crash on me... just not enough CPU and RAM resources sometimes.
  1. Need to Diasable Intergrated Graphics When Installing Graphics Card?
    By MegalosSkylaki in forum Technical Support
    Last Post: February 24th, 2010, 03:20 AM
  2. On board video card v/s Graphics card
    By ashish_sdr in forum Motherboards
    Last Post: August 21st, 2009, 03:20 AM
  3. Graphics card to replace onboard card
    By GlacierFruits in forum Graphics Cards and Displays
    Last Post: July 31st, 2009, 04:33 PM
  4. New graphics card but still crappy graphics
    By Rane_Sacre in forum Graphics Cards and Displays
    Last Post: December 26th, 2007, 06:20 PM
