Results 1 to 2 of 2
    Jun 2012
    If anyone can help out.. Video card problem
    Im not so computer savay i require some help i have a Dell Inspiration 530 and its operating system is window 7 home premium 32 bit memory 4096mb ram Processor intel pentium Dual CPU E2160 @ 1.80 Ghz,
    All i wanted to do was install this graphic card i been holding on to, but i have no graphic card cd and im not certain which is the right driver to install on the internet.
    The Graphics card is a -BFGR6600GTOCX-
    my computer has the same port and when i stuck the video card in, it was all static and different colors. i just tried going to the desktop and waited for the update to finish, because my computer detected the video card. and finally it display a 6600 geforce gt bubble. i just need a step by step process of what to do.. If anyone has the patience to help, i'd be much apprectiated. Thanks for reading, -James.
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,194
    4
    Hi and welcome to TechIMO!
    A 6600gt is a Nvidia branded graphics card. You will need to go to nvidia.com, choose your region, go to drivers then choose geforce drivers. From there you will need to manually choose it from the list (there will be an option for geforce 6 series) and it will bring you to the page.
    Once there, download it, and once you open it/run it, it will be an autoinstall and you just let it finish then reboot.
  1. Problem with Video Card
    By mazen222 in forum Graphics Cards and Displays
    Last Post: September 16th, 2007, 05:28 PM
  2. Video Card Problem/Freezing Problem
    By njolakoski in forum Graphics Cards and Displays
    Last Post: December 25th, 2006, 07:54 PM
  3. video card problem
    By smilecme in forum Multimedia and Audio
    Last Post: September 20th, 2005, 08:00 PM
  4. Problem with Video Card
    By AngelicLoki in forum Graphics Cards and Displays
    Last Post: October 17th, 2004, 08:58 PM
  5. moniter problem or video card problem?
    By nurdonsite2 in forum Graphics Cards and Displays
    Last Post: March 15th, 2003, 11:07 PM
