Thread: Need serious GPU help, please!
June 14th, 2012, 02:57 PM #1Junior Member
- Jun 2012
- 5
Hello, I have had this computer for awhile and recently it started messnig up, as in the graphics card in games like counter strike, arma 2, diablo 3, dota 2, ect. It starts getting very fuzzy and lines of the graphics go all crazy, here's a pic to the temps and what happened imgur: the simple image sharer, if I leave it on to much I will get BSOD akitpag or something like that, cant really remember, well please help me, nick.
The GPU is and ATI HD 4850.
I have 4gb of ram
A AMD P X4
June 14th, 2012, 03:23 PM #2
Hello and welcome to TechIMO!
This said, that screenshot is your typical sign of artifacting / overheating.
You mentioned a pic of the temps, but all I saw was 70*c - but it didn't say of what?
Run "HWmonitor" (free download) and advise us of the gpu temperatures during and while playing as well as the cpu temps in the same scenario.
Also "A AMD P X4" do you mean Amd Phenom X4? If so, as above, what temps is it displaying?
Have you cleaned out the dust in the case yet?
And lastly and very importantly, what power supply are you running?
We will need the make/model of the PSU, as well as the amps on the +12v rail (you will need to open up the case and physically check the sticker on the power supply to confirm, but if you have a link to the model it may display it as well)Main PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
June 14th, 2012, 03:29 PM #3Junior Member
- Jun 2012
- 5
June 14th, 2012, 03:34 PM #4Junior Member
- Jun 2012
- 5
Alright, first off sorry for double post, whenever I update with edit NO ONE EVER ANSWERS ME XD.
imgur: the simple image sharer is idle
imgur: the simple image sharer is while gaming
June 14th, 2012, 04:20 PM #5
Thanks for the pics.
The temperatures are well within normal range, so assuming the readings are accurate that should not be a problem at all.
Now, what has me concerned is your power supply. Though I don't always trust software for power supply readings, they are generally reliable enough to get an estimate.
Two problems - A) You +12v rail is running out of spec, and moreso B) when gaming it drops into very unstable range.
Even under hours of gaming, any quality power supply shouldn't fluctuate that much, especially a '600w' one that is overkill for the system.
Try to get the info including brand, model and +12v rail listed on the psu sticker asap.
Is there another card you can test in there, or more ideal, another pc you can test your card in?Main PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
June 14th, 2012, 04:40 PM #6Junior Member
- Jun 2012
- 5
June 14th, 2012, 05:26 PM #7
Yea, Logisys is a brand, and unfortunately one known for very low quality power supplies. In all reality with the one's I've seen from that company there claimed wattage is well over estimated and they are known for failure.
So judging from the pic and the known reliability of those psu's I'd try to swap it out asap, or simply not game on it in the mean time.
Now don't get me wrong, it could also be the video card, but that power supply needs to be swapped out as well, those +12v rail specs are wayyyyy off and unstable.Main PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
June 14th, 2012, 05:41 PM #8Junior Member
- Jun 2012
- 5
June 14th, 2012, 06:27 PM #9
No problem at all.
Before spending hard earned money on one, I also suggest you read over this - Power Supply Info
Though a bit dated it will prove invaluable to you when making your purchase.Main PC: AMD FX-8350 / 16gb DDR3 1600 / AMD 7970GE 1200mhz Core & 1600mhz Mem / Win7 Pro 64bit
GPU Help
By codemanjack in forum Graphics Cards and DisplaysReplies: 2Last Post: May 18th, 2012, 02:26 PM -
Which GPU for old PC
By jase888 in forum Graphics Cards and DisplaysReplies: 13Last Post: March 22nd, 2012, 06:45 PM -
New (old) GPU
By FakeMecksican in forum Graphics Cards and DisplaysReplies: 7Last Post: June 23rd, 2008, 11:05 AM -
Need a new GPU
By lukesparksoff in forum Graphics Cards and DisplaysReplies: 14Last Post: March 1st, 2008, 06:57 PM -
SLI single-GPU, multi-GPU, or antialiasing
By famosbrown in forum Graphics Cards and DisplaysReplies: 4Last Post: February 12th, 2006, 10:23 PM
Just what I need.... CCA FM 20 000E 20000E FM Broadcast Transmitter 20 KW 91 1 MHz w Filter | eBay :eek: Is that Part 15 compliant? :rofl:
