June 24th, 2012, 07:32 PM #1Junior Member
- Jun 2012
- 7
Could someone help me with identifying the graphic card slot?
I am completely clueless when it comes to hardware, so I was wondering if anyone could tell me what sort of graphic card slot is this?
http://i.imgur.com/Yb8mP.jpg
June 24th, 2012, 08:00 PM #2
Welcome to TechIMO!
The big one is a PCI-e 16X slot, and the 3 little ones, are PCI-e 1X slots.
What revision it is, I can't tell from a pic. 1.0, 2.0, or 3.0 Maybe 1.0, because, I don't see a lock.
Some 16X slots are only 8X or 4X electrically. (Yes, it sounds stupid)
Being the first and only one, more than likely it is X16 electrically.
If you give us the brand and model number, we can find out more.Hard Sayin Not Knowin
June 24th, 2012, 08:07 PM #3Junior Member
- Jun 2012
- 7
Well I have no idea if this helps but I got this from DxDiag:
System Information
Time of this report:
Machine name:
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Pavilion P6000 Series
BIOS: BIOS Date: 09/07/10 09:56:31 Ver: 6.09
Processor: AMD Athlon(tm) II X4 635 Processor (4 CPUs), ~2.9GHz
Memory: 6144MB RAM
Available OS Memory: 5880MB RAM
Page File: 2019MB used, 9738MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Radeon HD 4200
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x9710)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_9710&SUBSYS_2A92103C&REV_00
Display Memory: 2936 MB
Dedicated Memory: 252 MB
Shared Memory: 2683 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: HP f2105
Monitor Id: HWP2654
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: HD15
Driver Name: aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,atiumd 64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,ati umd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1124 (English)
Driver Version: 8.961.0.0
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/5/2012 22:20:04, 1067520 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-D450-11CF-E877-980ABEC2C535}
Vendor ID: 0x1002
Device ID: 0x9710
SubSys ID: 0x2A92103C
Revision ID: 0x0000
Driver Strong Name: oem70.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_RS880:8.961 .0.0
ci\ven_1002&dev_9710
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
It is a HP pavillion P6000 series :0
And thanks for the warm welcome
EDIT: FOUND MY COMPUTER MODEL! Newegg.com - HP Pavilion P6520F Desktop PC Athlon II X4 635(2.9GHz) 6GB DDR3 1TB HDD Capacity ATI Radeon HD 4200 Windows 7 Home Premium 64-bitLast edited by epiclyyummy; June 24th, 2012 at 08:28 PM.
June 24th, 2012, 08:31 PM #4
You will have to more specific.
The number should be stenciled on the board, itself.
Another board I found in that series has a number like this.
MCP73M01H1
What is it you want to do?Hard Sayin Not Knowin
June 24th, 2012, 08:35 PM #5Junior Member
- Jun 2012
- 7
I was just hoping to get some advice on how I should go about on upgrading my graphics card (cause right now its a measly integrated one).
Right now the power supply I have in there is 250W and theres that wretched radeon HD 4200, so I was trying to make sure that I find a card that will fit my motherboard :O
June 24th, 2012, 08:44 PM #6
Got it
Motherboard Specifications, H-RS880-uATX (Aloe) HP Pavilion p6520f Desktop PC - HP Customer Care (United States - English)
It is a PCI-e X16 ver2.0
Is that all you need, or are you upgrading the graphics card?Hard Sayin Not Knowin
June 24th, 2012, 08:48 PM #7Junior Member
- Jun 2012
- 7
Thank you so much!!!
And would you happen to have any advice on what I could do to improve my graphics card (mostly for gaming, but I don't really need a super super super good graphics setup)? I want to be able to run games that came out a year or two ago smoothly on decent settings :O but I don't really mind if it can't run games like Skyrim or Crysis 2 (newer games) smoothly on default settings
June 24th, 2012, 08:50 PM #8
Any PCI-e 1.0, 2.0, or even 3.0 should work.
1.0 slots with a newer card can be a problem occasionally, thats why I asked.
IMO, anything worth upgrading to, would need a 400watt power supply.Hard Sayin Not Knowin
June 24th, 2012, 08:52 PM #9Junior Member
- Jun 2012
- 7
Last question: does this graphics card decent as long as I find a psu suitable for it?
Newegg.com - SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity (100315L )
June 24th, 2012, 09:08 PM #10
I,m not a gamer, although I have a pretty good Idea of what is needed.
I only Flight Sim.
Our gamers are excellent, and should pipe in later.
They will also be able to tell, how good of a video card you can get before the CPU is bottlenecked, because you are close to that, but I,m never sure when you are that close.
If you give me a budget, I can probably give you a pretty good idea, because i can pick by price.
With video cards, price goes pretty exactly with performance.
A brand name power 400w supply (the only kind we recommend) should be about $50Hard Sayin Not Knowin
June 24th, 2012, 09:22 PM #11
It is last generation, and it was a step above what I consider the lowest high performance gaming card, the HD6770.
That will need a 500watt power supply.
I haven't looked in a while, but that sounds like good price.
AMD Radeonâ„¢ HD 6850 graphics
Cheapest 500w I can recommend.
Newegg.com - COOLER MASTER eXtreme Power Plus RS500-PCARD3-US 500W ATX12V v2.3 Power Supply
If you wait for the gamers, they can tell you much more.
This will give you a ballpark idea, as it is only close, and I would look further if the 2 card are right next to each other, but for the big picture, it is just fine.
PassMark Software - Video Card Benchmarks - High End Video CardsHard Sayin Not Knowin
June 24th, 2012, 09:23 PM #12Junior Member
- Jun 2012
- 7
Alright thanks for your time
Btw, is this psu any good? Ultra Limited Edition 550W Power Supply - ATX, Dual +12V Rail, Ultra Silent, Limited Edition, Lifetime Warranty with Registration at TigerDirect.com
I don't know if it's really that bad for it to be $11 dollars (on sale of course) or is it just a very good deal right now?
June 24th, 2012, 09:30 PM #13
According to Passmark, it is 30% better than a 6770.?
I guess my memory is failing.
June 24th, 2012, 09:32 PM #14
June 24th, 2012, 09:34 PM #15Junior Member
- Jun 2012
- 7
Oh alright, which would be the quality brand names for these? :O
June 24th, 2012, 09:35 PM #16
Find one off our good list.
As you will see, Ultra is on our bad list.
$40 with free shipping is amazing, you are not going to do much better, unless it is junk.
You are buying a quality Video Card, why would you skimp, on the most important part of the computer.
Power Supply InfoLast edited by stroyal; June 24th, 2012 at 09:38 PM.
June 25th, 2012, 12:00 AM #17
Antec - 450-Watt Power Supply - VP450
Newegg.com - XFX CORE Edition FX-777A-ZNF4 Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
6850 is fine, the 7770 is similar in performance, uses less power, and should be cooler running.
otherwise from Newegg, that Coolermaster PSU is fine (both the Antec on Best Buy and CM on Newegg, have the same Wattage rating for the +12V Rail, which is the important one out of the 3 Rails on a PSU).i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
June 25th, 2012, 09:11 AM #18
Same price.
That's why the 6850 dropped a little.
To say the least, Shyguy is a gamer.Hard Sayin Not Knowin
I need a graphic card for x4 slot.
By jksynapse in forum Graphics Cards and DisplaysReplies: 12Last Post: February 17th, 2009, 01:06 PM -
Which good graphic card for old computer with pci slot
By Milwaukee in forum Graphics Cards and DisplaysReplies: 1Last Post: September 27th, 2007, 04:17 PM -
Help with Graphic Card and AGP Slot Compatibility
By swell9 in forum Graphics Cards and DisplaysReplies: 6Last Post: July 23rd, 2007, 06:37 PM -
Best graphic cards for 1.5 volt agp slot?
By austin2359 in forum Graphics Cards and DisplaysReplies: 5Last Post: February 23rd, 2007, 10:18 PM -
Help identifying a card
By Drayco in forum Graphics Cards and DisplaysReplies: 6Last Post: November 30th, 2005, 08:01 PM
That's why Walmart is so unsuccessful.
IRS Lois Lerner Refuses to Resign
