Thread: Radeon HD 6850 display issues
June 26th, 2012, 05:36 AM #1Junior Member
- Jun 2012
- 3
Uploaded with ImageShack.us
What causes that to happen? How do i fix it?
I have a single msi radeon hd 6850, not overclocked or anything. this card isn't that old, so i hope it isn't broken. Any help on this issue would be greatly appreciated.
June 26th, 2012, 11:23 AM #2
Welcome to TechIMO!
This could be related to several issues. Did the tearing start after a driver update? Is the card running hot?
You can wipe then re-install drivers for the card to determine if its software related.
If it's an overheating issue, pop the sidepanel off the PC chassis and point a deskfan into the case and see if there is a difference. Also, check the fan(s) on the GPU to make sure they spin and utilize a temp probe to note the cards temperature. There should be a temp probe built into your card's driver UI.
Is this problem only occuring with WoW, or all games?Good job, friend-of-friends!
June 26th, 2012, 06:03 PM #3
V-sync enabled or is that off? Having it off in some games can create tearing as well.
June 27th, 2012, 01:11 AM #4Junior Member
- Jun 2012
- 3
V sync is on
this card is less than a month old so i haven't updated the driver ever since i installed it
it seems to run at about 50 - 60 degrees Celsius. I have 6 fans installed on this case
this problem has been slowly getting worse. is it just going bad all ready?
June 27th, 2012, 01:19 AM #5
temps sound fine, assuming those are at load when games are running.
did you install the drivers from CD included with Card, or download the latest from the AMD Website?
whats the rest of your system specs? CPU, RAM, Mobo, PSU, etc.
hows your temps for CPU, System, etc?i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
June 27th, 2012, 02:10 AM #6Junior Member
- Jun 2012
- 3
June 27th, 2012, 02:37 AM #7
hard to say what is causing it, whenever I've had similar problems in other games, it was usually the video card over heating, but 50-60C is actually pretty cool running.
the Corsair Vengeance RAM, is it 1600MHz rated stuff? Are you Overclocking your CPU at all? If no, are you running the RAM at 1600 or more "Stock" 1333MHz instead?
running at ultra or max, rather than high shouldn't be causing any problems, though if you have various things forced on via the Video card display drivers, that potentially could cause some problems, but if its everything run at max via in game settings, it shouldn't be causing this sort of problem.
When I mention forcing settings on, I mean for example, like with Elder Scrolls Oblivion, I can run the game fully maxed out via in game settings, and then via the Nvidia control panel I can enabled and jack up additional settings like higher Anti Aliasing levels, Triple Buffering, disable Vsync and some other tweaks, and get the game to look a tad bit better, and still have more than enough frame rate to spare (with just in game settings to max, the game runs at like 100-150fps at 1920x1080, with the additional settings it still runs at 80+ fps easily in outdoors, even higher with indoor environments)i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
June 27th, 2012, 12:26 PM #8
You haven't told us yet whether this effects only WoW or is a problem with all games.
If it's the former, there may be a solution. If the latter, sounds like it would be time to execute on your warranty.Good job, friend-of-friends!
6850 Radeon Hd not detecting
By Temuulen in forum Graphics Cards and DisplaysReplies: 3Last Post: April 8th, 2012, 11:11 PM -
Need help with Radeon HD 6850 Resolution issue.
By VirtuousNerO in forum Graphics Cards and DisplaysReplies: 0Last Post: October 27th, 2011, 07:18 PM -
HD 6850 Radeon
By jezebeth21 in forum Graphics Cards and DisplaysReplies: 9Last Post: October 11th, 2011, 11:50 AM -
Upgrading to the Radeon 6850 HD [Error]
By Shaed in forum Graphics Cards and DisplaysReplies: 4Last Post: April 30th, 2011, 12:35 PM -
Radeon HD 6850 vs 6870?
By yuppicide in forum Graphics Cards and DisplaysReplies: 7Last Post: December 30th, 2010, 10:19 PM
The two cards should both use the same driver install. With Afterburner, I know it will work on the non-MSI card as individually installed with no manufacturer lockout, but I don't know if it...
New Pc
