June 27th, 2012, 11:26 PM #1Junior Member
- Jun 2012
- 2
Screen splitting help? possibly video card problem
I have a AMD Radeon HD 6800
This happens when I start playing games, even ones that are somewhat old (Counter Strike Source anybody?).
The screen splits or moves to the side and comes out of the other side.
PICS:
You can see that the start icon is in the middle, like the screen was pushed to the right side and came out of the left.
This happened with a previous monitor, so I changed it and it seemed to solve the issue. It did not happen for a while with the new one, but then started again recently. The only way to restore it is to put the computer to sleep/ restart/ shut down and then turn it back on. I also changed the HDMI cable, but I'm guessing that its not the problem. Assuming that there are no other hardware to replace, other than the video card, then the video card must be the problem.
I appreciate any help given.
ps. I use a windows 7, 64 bit, i7 3.19GHz
June 28th, 2012, 01:24 AM #2
What is you screen resolution set to?
Are you getting your Audio through your Monitor?◄ it is what it is ►
June 28th, 2012, 12:03 PM #3Junior Member
- Jun 2012
- 2
June 29th, 2012, 05:10 PM #4
What happens when using a DVI cable?
Need to upgrade my video card, and possibly my power supply?
By Batts44 in forum Graphics Cards and DisplaysReplies: 6Last Post: November 15th, 2011, 07:25 PM -
Full Screen Game - Black Screen problem, ATI Card
By NickV in forum Graphics Cards and DisplaysReplies: 9Last Post: July 27th, 2009, 02:41 PM -
splitting mpeg video
By MDS in forum Multimedia and AudioReplies: 0Last Post: March 26th, 2008, 10:21 AM -
Video Card Problems! Possibly Drivers!
By eminem_rh25 in forum General Tech DiscussionReplies: 14Last Post: April 26th, 2005, 02:05 AM -
Splitting video files?
By melkor6925 in forum Multimedia and AudioReplies: 8Last Post: September 21st, 2003, 12:11 AM
Baconday?
