Thread: Help buying graphics card.
July 25th, 2012, 09:05 AM #1Junior Member
- Jul 2012
- 1
Hey all, I have a HP Compaq 6000 Pro Microtower PC. It is my computer I use at work, and my goal is to be able to play Diablo III on my down time.
Diablo III requires a nVidia GeForce 7800 GT or ATI Radeon X1950 Pro or better.
My PC currently has the factory standard Intel 4 Series Express Chipset Family built into the motherboard. My PSU is 320w.
I don't know much about graphic cards. I just need something passable to play the game. Preferably something that would not require me to upgrade my PSU. It must connect via a PSIe x16 port. If anyone knows any low cost cards that will do the trick It would be greatly appreciated!
July 25th, 2012, 09:49 AM #2
Welcome to TechIMO!
If you can provide the numbers we need to look up the details needed, on you EXACT unit, we can help.
HP Compaq 6000 Pro Microtower PC*-* Download drivers and software - specify product name - HP Business Support Center
Those requirements you poster, are minimum.
You need better than that for good performance.
Diablo III System Requirements - Battle.net Support
Any upgrade worth doing will need a 400 watt power supply.
If that 320watt is quality, it might work, but I doubt it is.
What is the brand of the power supply, and the 12v rail amp?
What is you total budget?
What CPU do you have?Hard Sayin Not Knowin
July 25th, 2012, 01:19 PM #3
Without knowing you info,yet.
This should cover the minimum requirements, and the power supply
Newegg.com - Computer Hardware, Video Cards & Video Devices, Desktop Graphics Cards, $25 - $50, GeForce G/GT series, GeForce GT 430 (Fermi)
But if you want recommended.
If it is the computer I think it is, you may have trouble with dual slot cards
so 6770 is probably out
Newegg.com - AMD 633897-ZH1 Radeon HD 6770 1GB 128-bit GDDR5 PCI Express 2.1 x16 Video Card
20% off with promo code, till 11:59 Wednesday.
450watt power supply
These are near recommended, also.
I believe the HD7750 is the best of the group, and uses the least power, of the top cards, as well as it is the newest.
Newegg.com - PowerColor AX7750 1GBD5-DH Radeon HD 7750 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
400watt power supply, or a really good 320watt.
Newegg.com - XFX HD-675X-ZDFC Radeon HD 6750 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card
If you want half way between the recommended and minimum
Newegg.com - PowerColor AX6670 1GBK3-HL Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Low Profile Ready Video Card
Still needs a 400watt power supply or a really good 320wattLast edited by stroyal; July 25th, 2012 at 01:39 PM.
July 25th, 2012, 01:36 PM #4
450 watt power supply.37.99 plus 3.99 shipping
Newegg.com - Antec VP-450 450W ATX 12V v2.3 Power Supply
All the good 400watters are actually more on New EggHard Sayin Not Knowin
Need help with buying a graphics card
By Jinxxxy in forum Graphics Cards and DisplaysReplies: 8Last Post: April 14th, 2011, 03:08 PM -
Buying a new graphics card
By Razor1911 in forum Graphics Cards and DisplaysReplies: 1Last Post: November 29th, 2009, 05:18 PM -
I Am Buying A New Graphics Card
By NoJabbaNoBogRoll in forum Graphics Cards and DisplaysReplies: 34Last Post: October 17th, 2006, 07:09 PM -
Buying Graphics Card
By 2weasel2 in forum Graphics Cards and DisplaysReplies: 2Last Post: September 11th, 2006, 01:17 AM -
buying a graphics card?
By Johnny8918 in forum Graphics Cards and DisplaysReplies: 135Last Post: May 29th, 2005, 10:05 PM
Good Morning friends are you ready to enjoy your weekend as you want just take a look and have fun. Greys Anatomy Season 9 Episode 24 Good Luck Charlie Season 4 Episode 4 The Cleveland Show...
Good Luck Charlie Season 4 Episode...
