Results 1 to 12 of 12
    Jul 2012
    5
    Upgrading My graphics card and need some help.
    I was looking to upgrade my card to a Evga geforce gtx 550 ti, but I needed to know what type of of fps this thing would give me if I where to run say Crysis 2 or Battlefield 3 on high to very high settings on a 1680 x 1050 display. I'm running an i7 with 16gb of ram if this helps. And thanks in advance.
    Mar 2007
    My own little world.
    11,764
    Hi, and WELCOME TO TECHIMO - from the Folding@Home Team [#111]...!
    I've asked the guys to have a look, but you might need to wait for them to wake back up again......
    NLM
    Jul 2012
    5
    Thanks for the quick reply. I was also wondering what would be the difference in fps on the same games with and the same settings mentioned above with the Evga geforce gtx 560 ti compared to the Gtx 550 ti.
    What? SoloCamo's Avatar
    Nov 2004
    Burning in Florida
    15,195
    4
    As above, Welcome to TechIMO!
    I actually used to own a gtx550ti, it's a good card at it's current price point. However, it unfortunately will not be able to play Crysis 2 or Battlefield smoothly on high/highest settings, even at 1680. The I7 is a great cpu, and you've got plenty of ram so you are fine in that respect.
    The 560ti is quite a bit better than 550ti and will be able to play the game on higher settings at your resolution (though not maxed out.
    How much do you have to spend (and what ccountry are you based out of)? Also, what is the make and model of your power supply?
    On top of that, what video card do you currently have?
    Mar 2007
    11,764
    Based on their IP, it looks like they're in Canadia..
    #HereToHelp..
    ;o)
    Jul 2012
    5
    Thanks for the help I do in fact live in Canada and the card I am running now is the card that came with my computer which is the Geforce Gt 630. It is not able to run most new games at a decent frame rate even on the lowest settings. I'm looking to spend at most 350$ so it looks like ill be going with the 2gb version of the gtx 560ti. Not sure of the make or model of the power supply. It came with the computer, all I know about it is that its 300 watts. I know I need to upgrade this to at least 500 watts if I want to run the 560ti, so most likely I will end up with something between a 600 to 700 watt power supply. What do you guys think?
    Nov 2004
    Burning in Florida
    15,195
    4
    Quote Originally Posted by ChokingHazard View Post
    A quality 500w-600w is plenty for that system, and yes, a 560ti is a nice card.
    However, just to clarify is that 350 usd, or? If it is 350 usd, you can actually get a bit better card and a good power supply to complement your i7.
    Jul 2012
    5
    350$ Canadian.
    Minnesota
    17,377
    If you can wait a few more weeks, I'd wait for the release if the gtx 660 series cards for the price range.
    Other wise the Radeon hd 7870 would be a better deal for the price range.
    Jul 2012
    5
    I Dont mind waiting but will the 660 be better then the 560ti or 570?
    Nov 2004
    Burning in Florida
    15,195
    4
    With the specs released so far, it should be closer to a 580, if not slightly ahead of it at times.
    Minnesota
    17,377
    well if its to compete with the Radeon HD 7870 in price range, it better damn well, as that card by itself already beats the 560 ti and rivals the 570. So the 660 better, or should beat any of those, and come close to the 580 if not best it as well, as Solo mentioned.
    Otherwise, Nvidia has another blunder to add to its line up, sort of like AMD's current FX series CPU's, hopefully fixed with the Piledriver CPU's coming out in the next couple months.
  1. Upgrading my graphics card
    By danny85 in forum Graphics Cards and Displays
    Last Post: February 4th, 2012, 04:17 PM
  2. upgrading my graphics card
    By torak289 in forum Graphics Cards and Displays
    Last Post: January 1st, 2012, 04:16 AM
  3. Upgrading a Graphics Card
    By hahaloser in forum Graphics Cards and Displays
    Last Post: April 28th, 2011, 07:32 PM
  4. Need Help With Upgrading Graphics Card
    By MaxGG in forum Graphics Cards and Displays
    Last Post: February 7th, 2011, 07:37 PM
  5. Upgrading a graphics card
    By gef2003 in forum Graphics Cards and Displays
    Last Post: April 24th, 2007, 02:26 PM
