Thread: 7950 display problem
August 19th, 2012, 10:56 AM #1Junior Member
- Aug 2012
- 5
Sometimes my computer does not recognise my GPU and requires up to several restarts till it shows.
I have used several HDMI cables and monitors with the same problem.
If I connect straight to the mobo then it works but then I can't find the graphics card in my devices.
But then a few restarts later it will be detected and I can run BF3 perfect for a few hours until I turn it off.
Any help would be appreciated.
System Specs
Intel I5 3750k OC 4.0 Ghz
Gigabyte GA-Z77-D3H Mobo
Corsair XMS3 DDR3 1600MHz
PowerCool 850w PSU
PowerColor Radeon HD 7950 3GB
August 19th, 2012, 09:05 PM #2
I would begin by replacing the power supply, that is either the main culprit or will end up being a problem for you later.
Random issues like this are very likely power related.
Thats not saying that it CANT be the card itself, or that the power supply has already done damage to it.
But until you replace it with a reliable one, your fishing in the dark.
Power Supply Info
August 20th, 2012, 04:14 AM #3Junior Member
- Aug 2012
- 5
Is there any way I confirm this is the problem before I buy a new one?
August 22nd, 2012, 05:04 PM #4
Power Supply Info - Tech Support Forums - TechIMO.com
The point is you only actually need a 400W PSU to run your PC as is....
but it has to be a good brand and have enough +12v amperage.
A bad PSU will cause random issues and make any diagnostics nearly impossible.
I'm willing to bet its the root cuase in the first place...
AAnd the worst part of a dodgy PSU is when it DOES blow it takes out all your expensive hardware with it...
Good models use power protection hardware to minimize or eliminate "blowback" to the rest of the components
August 22nd, 2012, 06:33 PM #5Junior Member
- Aug 2012
- 5
Okay im looking at the Corsair CX600 and the Coolermaster GX RS650.
Are these of good enough quality or could you kindly recommend me one?
August 22nd, 2012, 08:42 PM #6
I'd go with the Corsair, but either would be fine
August 22nd, 2012, 09:17 PM #7Senior Member
- Apr 2005
- Location
- Australia, Sydney
- 520
Test the Card in someone elses computer. If it detects 10/10 times, then you know its not the card. And would then come down to the PSU, or possibly motherboard Pci express slot. I doubt that though and would limit by guess on the PSU.
August 23rd, 2012, 10:08 AM #8Junior Member
- Aug 2012
- 5
Okay i ordered the Corsair Enthusiast Series TX650 V2. Meanwhile i have tried an old GFX card and it worked fine so the slot isn't the problem.
Ill report back my results with the Corsair when i get it, many thanks for your help.
August 23rd, 2012, 12:11 PM #9Junior Member
- Aug 2012
- 5
I found this thread from a guy who has the exact same problem, his English isn't great but it seems the PSU was the cause of the problem, hopefully mine is and not the GPU!
[other] No Display in core i7 computer. Restart many times to get Display. - Ubuntu Forums
Evga 7950 Gt -Please Respond Quickly-
By xlastshotx in forum Graphics Cards and DisplaysReplies: 4Last Post: July 1st, 2007, 07:49 PM -
7950 GX2 Laggy in BF2
By Godfish in forum Graphics Cards and DisplaysReplies: 3Last Post: March 20th, 2007, 09:34 AM -
7950 gt ko superclock vs 8800 gts
By carajean206 in forum Graphics Cards and DisplaysReplies: 2Last Post: December 15th, 2006, 04:50 PM -
7950 GT 512 or x1950 XT 256???
By ThePec in forum Graphics Cards and DisplaysReplies: 6Last Post: November 24th, 2006, 12:37 PM -
New NVIDIA 7950 GX2 1gb is out!
By nubcake in forum Graphics Cards and DisplaysReplies: 5Last Post: June 7th, 2006, 12:36 AM
:cool: Sounds like a winner Surreal! Which one? The red/green, green, blue, brown, or white/green?
